PVC aero ports
Zbak
The above based on rated power, if you can build a somewhat larger box I would recommend going with a slot port.
Could you do 8" port? I think that would be spot on, and a common combination with two 12"s.
Where the hell can you buy a 8 inch port?! Pvc that is?? Anyone
and why do you think I should go with a bigger box that is slot port? Just wondering
Ok bigger because slot ports take some more space than round ports, the reason to go slot is that you can set port area at will and your application will likely benefit with greater port area if you are going to push above rated power.
For stuff bigger than 6" forget PVC, go with concrete form tubes like this: https://www.menards.com/main/building-materials/concrete-cement-masonry/forming-tubes/sonotube-commercial-8-x-12-heavy-wall-water-resistant-concrete-form/p-1398480.htm
Builds:
FREAKING GENIUS OVER HERE!!!
Yes that works well combined with some resin and some wood for flares and stuff.
Made two 4" ports in one of my boxes with similar material
Edit: done it in two boxes i forgot :P
i cant quite tell if ur being sarcastic <_<
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
  • Who's Online   0 Members, 0 Anonymous, 3074 Guests (See full list)
