feathered1iron Posted August 24, 2015 Report Posted August 24, 2015 So I currently have 2 RF 51412 12s in a ported midgate box and 1 RFt1500bd although I would like to add a second for the subs. Which mid/high/amp setup would you guys recommend? I am new to car audio to keep that in mind but I would rather spend the $ to have something that I will like for awhile and also in case I had a more aggressive sub/amp/box combo. Thanks for any help guys. Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
jcarter1885 Posted August 26, 2015 Report Posted August 26, 2015 How much work you wanna do, fiberglass? Stock Locations? Passive or Active? Amount of amps you want to dedicate to the front stage? Just to get you started. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Broke_Audio_Addict Posted August 26, 2015 Report Posted August 26, 2015 A nice component set and 4 channel is all you need to keep up with those. Two 1500bd's will be way too much for those t1's. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
White Lightning Posted August 27, 2015 Report Posted August 27, 2015 I'm assuming you're in an Avalanche or Caddy ?? Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
Keagan-Z06 Posted August 31, 2015 Report Posted August 31, 2015 seems like a caddy. HU: Pioneer 4100 NEXSubs: 2 Rockford Fosgate R2SD4-10"Amp: Rockford Fosgate P500-1bd wired @ 1ohmFront: Polk Audio Components DB6501Amp: Pioneer GM A5602 wired @ 4 ohmRear: Polk Audio Coaxials db651s(2) OM-1s, (1) VM-1
