Isobaric 4th for 8 15s in a ford ranger extended cab.
toolshed
You realize doing the isobaric you are using double the subs and double the power to get similar output as you could with just 4 subs?
Under the current circumstances, I am running aprox 1000 watts per sub and they can't handle it. If I go isobaric, then I will gain space and can push them harder...I might be wrong. Just an idea. All I know is I have 8 subs and would like to get in the 150s :)
Iso loading halves Vas. So you will halve the size of the sealed chamber and double your thermal capabilities.
You also halve your sensitivity, but you should easily be able to compensate for that with the efficiency of a bandpass.
Sound like an cool project. Get to work.
Do you have t/s parameters for these subs? You should not touch your system until you have fully figured out what you are getting from the new box, 4th bandpass will not perform nice with any sub.
16.5 inches from seat to back wall
48 wide
40 tall
You measured wrong. There's more room than that. Keep in mid you can gain more space by removing the plastic paneling on the sides and cutting the thin sheet metal.
I do not have the parameters. I used one in a 4th order and got good results. it was in a blazer with the port faced to the rear in the back
  • Who's Online   0 Members, 0 Anonymous, 3034 Guests (See full list)
