Calculating Parallel Impedance with a Calculator
Stephen13
Don't know if this has been brought up here before so my apologies if it has.
Here's how to use a calculator to determine impedance of parallel conneted voice coils. You'll need a scientific calculator to do this. What you'll be using is the 1/x (one over x) function. Let's say you want to connect two 8Ω voice coils in parallel. You would enter the figures like this...
8
1/x (usually done by pressing the 2nd function button first and then the 1/x button)
8
1/x
1/x
When you're done your calculator should display 4
If you wanted to know the impedance of three 8Ω voice coils in parallel...
8
1/x
8
1/x
8
1/x
1/x
Your display should now say 2.6666666667
Hope you find this useful.
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
True, but a calculator doesn't need an internet connection. ;)
You don't really need a 'scientific' calculator to calculate parallel loads.
For the same impedance you can just do (ohms) / (total number in parallel)
Ex: 3 8ohm speakers = 8/3 = 2.66
:pardon:
:pardon:
And if they are dvc just double the total number in parallel.
So: 3 dvc 8 ohm woofers, in parallel,
8/6=1.33
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
what about 16 1.3 ohm coils? :P
Hammerdown... 1%
:pardon:
Good point. My procedure works for speakers but I mainly use it while breadboarding circuits and have to parallel different value resistors to get a specific value that I don't have a resistor for.
  • Who's Online   0 Members, 0 Anonymous, 3006 Guests (See full list)
