need help picking sub/design/ aero port.... got a big headache
towncarblue
Will this work for your space?
1.5 cu ft net airspace
27 sq in port area tuned to 33 Hz.
Builds:
So here is a suggestion 12.5" in depth, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 1 7/8", figure is just an assembly guide:
i need to go to my car and see if i can add .25 inches to the height and width
unfortunately my car is not near me right now, its good on gas so a family member borrowed it
will post when i do the measurements
well....
i just went into my friends honda accord. checked out the trunk and realized , i cant do either of these boxes.
im losing too much trunk space , i go to costco alot and i need every inch i can .
im so sorry for putting you all through this :sorry::sorry: . i do plan to build one of these boxes for my pathfinder
because these look like some perfectly tuned boxes , i always wanted to build a ported box and see what all the praise is about.
my only option now is sealed . i have about 1.5 cuft after displacement .
should i get a single si mag v3 or should i get two e-10's ?
i know it wont go as deep as the ported box :lol: but which of these setups will go deeper / lower ?
and to
Triticum Agricolam
can i get the enclosure specifications for your sub box posted
If you want to go with a ported box you could fit a ported 10" in the space you have.
Here are the specs you need to build the box I posted. I copied Joe X's spec sheet since it works so well:
Enclosure Specs
Fb = 33 Hz
Vb = 1.5 ft^3
External Height = 15"
External Width = 28"
External Depth = 13-1/2"
Port W x H = 2" x 13-1/2"
Cut Sheet:
Front = 13-1/2" x 24-1/2"
Inner baffle = 13-1/2" x 23-3/4"
Back = 13-1/2" x 26-1/2"
Left/Right side = 13-1/2" x 13-1/2"
Top/Bottom = 13-1/2" x 28"
Front to Back Port 13-1/2" x 10"
Left to Right Port 13-1/2" x 18-3/4"
Here is a top view showing how everything is put together:
Builds:
well....
and to
Triticum Agricolam
Just do what everyone else does and mock up a box out of cardboard and see how much room you can give to a sub. Then design around that
GCON 10" ported. A little harder to build but it can still be done, figure is just an assembly guide:
  • Who's Online   0 Members, 0 Anonymous, 8476 Guests (See full list)
