feathered1iron Posted September 9, 2015 Report Posted September 9, 2015 Hey guys, just recently got 2 RF t1d412's in a attrend(42hz) midgate ported box and 1 RF t1500 amp on stock power and door speakers. Solid install, reputable shop however it doesn't hit as hard as I expected although this is my first experience with aftermarket car audio. Possibly gains turned down?" Any ideas? Thanks Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
reedal Posted September 9, 2015 Report Posted September 9, 2015 ^^ yep. get a design from someone on here and build your own enclosure, or have a reputable local shop build one for you using the subs specs, and have it tuned around 35hz, and you'll be much happier SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
feathered1iron Posted September 9, 2015 Author Report Posted September 9, 2015 So like a custom blowthru design? Also, would it help if I ran another t1500? Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
Broke_Audio_Addict Posted September 9, 2015 Report Posted September 9, 2015 You definitely need a custom enclosure. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Broke_Audio_Addict Posted September 9, 2015 Report Posted September 9, 2015 So like a custom blowthru design? Also, would it help if I ran another t1500? Two 1500's is too much for those subs. One 2500 is the way too go. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
feathered1iron Posted September 9, 2015 Author Report Posted September 9, 2015 Well I already have the t1500 so I guess im kinda screwed on that part. Anyone know of someone who could build a box for me or give me specs for it? its in a 05 Escalade EXT. I live in Hampton Roads VA Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
Broke_Audio_Addict Posted September 9, 2015 Report Posted September 9, 2015 4.25cuft net tuned to whatever you like. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
feathered1iron Posted September 9, 2015 Author Report Posted September 9, 2015 What style box would you guys recommend? I feel like a blowthru may leak? Also, will there be a significant difference? Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
bcbrassard Posted September 11, 2015 Report Posted September 11, 2015 So like a custom blowthru design? Also, would it help if I ran another t1500? Two 1500's is too much for those subs. One 2500 is the way too go. I disagree with you there. 2 T1D412's, each in 4 ohm of the T1500 would be 1400 rms. they will handle that easily. I have ran one in 1 ohm at almost 2K. But a new enclosure is where the OP will gain the most and them change the amp up. But i say go with another T1500.
