Eb flex Welding Cable
my cuisine works at airgas he told me to compare to audio wire you have to up size like 2/0 welding=1/0 audio wire.I do know my shca 1/0 is bigger then the 2/0 welding he carries
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
1/0 "car auido" is roughly equivalent to 2/0 welding. That's true. Well, the good brands anyway.
The difference between 1/0 and 2/0 is about a 15% increase in ampacity. Or what would amount to an additional .2v of voltage drop @ 300A @ 20ft.
Oxygen content really only has a impact on corrosion resistance,
I can't find any evidence of this. Can you cite your source?
Oxygen is purposely injected during smelting to scavenge impurities.
Not really any legit studies but just educated guesses ive read from people much smarter than me.
Although I've read that copper oxidation is actually conductive as well so maybe it really doesn't even matter.
And what's any of it matter really anyways since we use shit metals to terminate lots of our connections?
Also what does scavenging impurities during smelting have to do with oxidation resistance?
I'm not sure how to answer that. I only mentioned it for those that didn't realize it was added purposely and apparently has no adverse effect on corrosion resistance.
I can't find a single resource that would indicate the higher concentration of O2 in ETP would accelerate its corrosion. The only thing I *could* find was something called hydrogen embrittlement that occurs somewhere between 370* and 500*C.
That's interesting for those that solder their lugs. Score one more for crimping!
I mean the definition of oxidize would lead me to believe that a higher oxygen content would lead to a faster rate of oxidation how much faster I have no clue but that's what I get from the term.
ox·i·dize
\ˈäk-sə-ˌdīz\verb
: to become combined with oxygen
Full Definition
ox·i·dizedox·i·diz·ing
transitive verb
1
:to combine with oxygen
2
:to dehydrogenate especially by the action of oxygen
I would crimp but I don't have a trailer hitch available to do so.
:peepwall:
ofc means oxygen free copper. meaning its free from oxygen. there is no oxygen in the wire. copper lugs corrode when exposed to oxygen.. best wire for corrosion is tinned copper. if its not tinned you have to really cover the wire from oxygen.. i have kicker wire that is silver tinned for over 5 years (8 years to be exact) and no corrosion. ive seen welding wire and regular ofc wire corrode after a few months to a year
my sky high 2/0 corroded from an exposed terminal.. you really need to cover ofc wire thats not tinned
its the elements not just oxygen that contributes to corrosion
Ok, so copper oxidation is actually a "semiconductor". But...
These oxide layers are so thinhowever that for all practical purposes they do not interfere with theconductivity across such layers.
Furthermore... the thin layer of oxidation actually protects the copper from further oxidation. So there's that. I suppose that's a bit like galvanization in that regard.
That's what I've read as well.
  • Who's Online   0 Members, 0 Anonymous, 831 Guests (See full list)
