Ok. It's hard to make out if it's lit only when you turn it or if it's constant.
First: did you check the signal coming from the head unit for your head units max clean volume as stated in the directions?
Second: leave the head unit at the maximum clean volume, amp gain all the way down. Is the distortion light on or off when checking the amplifier output for distortion?
Third: if the distortion light blinks only when you adjust volume or gain, then that's fine if it goes away when you stop. If it's constantly on, you need to back the gain down until it disappears.
As long as you follow the direction book front to back, it's a pretty easy tool to use. The video wasn't too helpful in troubleshooting your issue, at least not to me.
The battery is new and ill check the rca cable they look fine to me doe
I notice the distortion comes on even setting the gain down maybe the head unit ?
I'm thinking I'll disconnect the front speakers n see if that has anything to do
I'll post a video of it Ina few
You can't just look at a pair of RCA's and just say, "they look good to me". Doesn't work like that. As well, I can tell you didn't follow the instructions for the DD-1 because in it it specifically states to disconnect your speakers when tuning the amp.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
i will follow these steps and get back to you brother
yes you are correct sir i did use the same RCA on the CC-1 and it was fine :) and i did read the instructions more then once i just wanted to show a quick video thats why i had music and had my speakers connected
Watch the video here https://goo.gl/IfKQzM
Bro.... are you playing music or tones while testing? Sounds and looks like music....
yes i was playing music cause i wanted to show thats how it is even when playing tones but again ill do the test all over again :)
Edited by ajsmoke
THIS ^^^
Follow my Tweet (Twitter)
well just back from work and i did d/c the speakers that the headunit was wired to... and it worked :) woohoo
but my other problem is the CC-1 cant get any signal im trying set the subsonic
Turn subsonic all the way down > make sure there is no hi pass filter on the head unit set to act as a subsonic filter for the sub level > double check you're using the correct tone > all wires/probes are properly connected
Lastly, the CC-1 has two operational settings if I'm not mistaken: 1)set filters, 2) gain match. Make sure you don't set it to gain match or it may not show that the signal is there until you revert it back to setting filters.
