US Alternator 250 amp alt putting in some work *New video Added*
This is with shitty cadence 1/0 cca. Gonna add some better wire soon
Brandon
2000 Furd Ranger supercab 4x4
System:
welding wire throughout the truck
USalts 390amp Hairpin
Juicebox in stock location
8 Banks of maxwell supercaps
2 American Bass Vfl 1100.1 wired to .35 each
2 Fi Audio Sp4 18's ( the DD sc 9918's smoked)
Pioneer radio with Soundstream PA mids Powered by a nice sized soundstream 2 channel
It's pronounced (dain-ja rain-ja) :ph34r:
2001 2 door focus
1 DD9918 SC
Sick idle! It is doing work!
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I must be missing something. It did 247 amps but it was all at 12.3 volts even at high rpms
His amp draw is exceeding what the alternator can produce thus you will expect a voltage drop to next source of power. Iirc he is drawing around 500 amps.
If he wasn't dropping voltage you wouldn't see the full output potential of the alternator because he would be holding 14.8 volts.
BMW M340 xDrive
That voltage isn't typical. I went balls out to make the alt stay loaded down.
Just got some 2/0 ofc sky high for the alt run. Should make her happy.
Just have a juicebox black cherry and black berry up front and a bank of Maxwell's
Brandon
System:
2001 2 door focus
1 DD9918 SC
And for reference before the alt I'd drop to 11v flat with 5 batteries and the bank. So the alt is helping a shit ton
Brandon
System:
2001 2 door focus
1 DD9918 SC
This is correct. If you held higher voltage you would not see the monster amperage. That alt is doing work. Especially when hot. That thing is doing exactly what it should be doing, and then some.
