Using speaker wire as power wire (vm1)
Wiring up my smd vm1. Would there be any reason not to use a good ofc speaker wire vs "primary wire". Being that it is only a voltmeter that has a low draw I figured that would be fine. Just wanted to double check before I run the wire back to the amp.
1999 Lexus GS 300
Pioneer DEH-80PRS
Singer 240 Amp (Will be installed later)
Northstar Group 31 & 24
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds 6.5 Meso Components
CT Sounds Tropo 6.5
I wired up both of my voltmeters using old speaker wire I had 12 or 14 gauge. Works fine doesn't draw a lot of power. I did similar thing and twisted wires looks a lot better just make sure u tape, heat shrink, or ziptie every coupler it will come unraveled.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Awesome thanks for the input. It seemed like it would be fine but I wanted to run it by you guys first. That vm1 is so much more accurate than the other cheap meter I had. The old meter stated that I would drop to 12.4 whenever the bass hit, vm1 I barely drop below 13.5. Of course I double checked with a dmm at the battery/amp and its' correct
1999 Lexus GS 300
Pioneer DEH-80PRS
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds Tropo 6.5
I used speaker wires, I think either 18 or 16.
HU: Pioneer 4100 NEX
Subs: 2 Rockford Fosgate R2SD4-10"
Amp: Rockford Fosgate P500-1bd wired @ 1ohm
Front: Polk Audio Components DB6501
Amp: Pioneer GM A5602 wired @ 4 ohm
Rear: Polk Audio Coaxials db651s
(2) OM-1s, (1) VM-1
dupe
(2) OM-1s, (1) VM-1
yeah the wires coming off the VM-1 and are just sense wires not power wires that cause a draw of amperage. any distance and any gauge should be fine
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
  • Who's Online   0 Members, 0 Anonymous, 1545 Guests (See full list)
