HONDA ACCORD overkill rebuild
A lot of members may remember my original Honda accord system that I was working on a couple months back
but Its just certain things I didn't really like about it. For 1 I was rushing it and for 2 I didn't like my electrical/ wiring.
So I decided to start fresh and not start building until I have all the equipment for the build. Some may not agree with
the equipment I use but I will get the most out of what ever I use for the build. This time around it will be an overkill
some might say due to how many speakers and amps I will be using. But the main reason for the overkill
is because I do alot of installs for many different people around my area.This will be a good way to show
them how many different ways I can install speakers and also show all my custom/fabrication skills. Though
it will be a daily driver its also my show car.
MY PLAN
4 way system
20)Speakers
4) 12" SUBWOOFERS ~ 0HZ-63HZ
4) 8" MID-BASS ~ 63HZ-400HZ
4) 6.5" MID-RANGE ~ 400HZ-4KHZ
2) 4" MID-RANGE ~ 400HZ-4KHZ
6) BULLET TWEETERS ~ 4KHZ-20KHZ
5) AMPLIFIERS
3)2Channel amps
1)4Channel amp
1)Mono-Block amp
ELECTRICAL
2)AGM batteries ~1 up front 1 in the rear
80)Feet of 0/gauge.((Doing 2 runs))
40)Feet of 4 gauge
500)feet of 14 gauge((all speakers seeing 14 gauge wire))
100)feet of 12 gauge ((SUBS))
HEAD-UNIT/PROCESSING
Pioneer 7"head unit
3 way Audiopipe crossover
2 rear 9" Monitors
((Like I said before alot will not agree with my equipment choices but I will get the most of it))
I've already started buying some of the equipment and have a couple of pictures of some of
the equipment. I will not start building until everything is brought. Now pics
THE RIDE
CROSSOVER POINTS
The equipment I have so far.
More pics to come! But for the next two months just expect new equipment pics. My last amplifier I need for my subs will most likely be
a HIFONICS BRX 2400.1D.Stay tuned
Sweet as, I wouldn't bother with 4inch mid-range drivers if you already have 6.5inch mid-range driver covering the same freq
This, I understand you are using your car for presentation and advertisement of your work but as a basshead I would like someone using less equipment and still having great output. No need for two speakers playing the same frequencies as stated above. Less speakers and better brands would yield you greater results, I just feel like you could do way better than that especially if you want to appeal to local customers.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
looking forward to this build!!
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Alot of people can't afford the higher-end brands.I'm just trying to show them that you don't need jl/sundown/Rockford to be loud,clean,and clear.
I dont even mean higher end brands, my Eminence speakers sound better than most car audio brand pa speakers. There is other equipment besides high end car audio brands especially if your going the pro audio route, Faital Pro makes a hell of a pa speaker for an affordable cost. Check out stores like madisoundspeakerstore.com or usspeaker.com in the future. Nothing wrong with the equipment as everyone takes different paths but it is the not the end of all solution for budget equipment. Im tuned in for sure. I wouldnt put speakers somewhere just because I have dash pods, take the dash back to factory and ditch the 4" speakers.
AudioControl DM-608
Tuned in, lots of equipment.
Not my favorite rims but meh. =)
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Tuned in to see this build looks like it could be decent :) ...
It's more the build than equipment used that makes for a clean setup... Yes equipment does play a role but with the right build you can make lower end equipment sound great.
Can't wait to see what you accomplish
Team MaxRetribution
Si Vis Pacem Parabellum
