magillaru Posted November 10, 2015 Report Posted November 10, 2015 I've spoken to a few of you through PMs already regarding this design. You know who you are and I appreciate the help. Originally, I was planning on around 3.5 cube per sub due to the power I'm planning on running. What would be the max net volume I could get away with without losing cone control or having issues with unloading running 5-6k per sub. Thanks in advance! Singer Alternators Team Asshole #anothershittysingerbuild
Damien Shipper Posted November 10, 2015 Report Posted November 10, 2015 5-6k amp or 5-6k clamped power? Big difference there. Get yours today at www.wcCarAudio.com
magillaru Posted November 10, 2015 Author Report Posted November 10, 2015 Good point. Will either be two 1100.1s @ .5 ohm each or four 6-7k amps @ 1 ohm each. Singer Alternators Team Asshole #anothershittysingerbuild
Ninja_v1.0 Posted November 10, 2015 Report Posted November 10, 2015 you're going to want 3.5-4 and no bigger what ever amp you choose make sure you are going to be able to deliver about 4k to each sub.. anything less and you might as well go with a sp4 When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
daimer Posted November 10, 2015 Report Posted November 10, 2015 I think 3.5 will be a bit small for a 15", even at that power. Depends on the response you would like to get and what is the frequency that you want max spl at.The benefits of a smaller low tuned enclosure are that you have better frequency range and that the cone control is better at higher frequencies.On lower than tuning frequencies the control is similar, because below tuning you're basically playing free air.The negative side is that cone excursion at and around tuning will be less, so it won't be that louder on those frequencies and will get hotter because there is less impedance rise (more power) and less cone movement to cool off the coil.The benefits of a bigger low tuned enclosure are thermal power handling at and around tuning, will play louder near tuning and you can use a shorter port.Negative side is that you will have a narrower bandwidth (loss of higher freq's). The less cone control above tuning can be compensated with a proper LPF adjustment. Probably you will be good with 4 - 4.2 cu.ft.That's my opinion, based on my experience with other subs. Someone correct me if I'm wrong. My humble build log: http://www.stevemeadedesigns.com/board/topic/192602-corsa-b-daily-build-with-12-ground-zero-new-box-in/ Single Zv4 Rev.2 15" on a 10k amp: http://www.stevemeadedesigns.com/board/topic/201434-my-reviewtest-of-the-zv4-rev2-15/
Massivespl Posted November 10, 2015 Report Posted November 10, 2015 I think build as big as u can and start shrinking until u find the sweet spot. c-pillar flat wall 157.11db on music 2 crossfire 8k 4 NSV3 18s 4 crescendo 10s 4 Rockford pro 6.5s Quad excessive amperage 350alts 4 juicebox 3100s
magillaru Posted November 10, 2015 Author Report Posted November 10, 2015 you're going to want 3.5-4 and no bigger what ever amp you choose make sure you are going to be able to deliver about 4k to each sub.. anything less and you might as well go with a sp4 Yeah, that's what I figured. I'm trying to do a center port (walled at b-pillar) without having to bend the port and get the low tuning I want (low 30s). Oh, I know these things can take some power and that's exactly what I'm planning on doing, which is why I'm really tempted to do four 750.1s Singer Alternators Team Asshole #anothershittysingerbuild
magillaru Posted November 10, 2015 Author Report Posted November 10, 2015 I think 3.5 will be a bit small for a 15", even at that power. Depends on the response you would like to get and what is the frequency that you want max spl at. The benefits of a smaller low tuned enclosure are that you have better frequency range and that the cone control is better at higher frequencies. On lower than tuning frequencies the control is similar, because below tuning you're basically playing free air. The negative side is that cone excursion at and around tuning will be less, so it won't be that louder on those frequencies and will get hotter because there is less impedance rise (more power) and less cone movement to cool off the coil. The benefits of a bigger low tuned enclosure are thermal power handling at and around tuning, will play louder near tuning and you can use a shorter port. Negative side is that you will have a narrower bandwidth (loss of higher freq's). The less cone control above tuning can be compensated with a proper LPF adjustment. Probably you will be good with 4 - 4.2 cu.ft. That's my opinion, based on my experience with other subs. Someone correct me if I'm wrong. This is exactly why I'm having this problem. This is going to be a daily musical setup that will be able to demo for hours (or at least that's the plan). It will see the meter but not competing, just to see what it can do. Singer Alternators Team Asshole #anothershittysingerbuild
magillaru Posted November 10, 2015 Author Report Posted November 10, 2015 I think build as big as u can and start shrinking until u find the sweet spot. That works too but I want a plan going into it. Singer Alternators Team Asshole #anothershittysingerbuild
Keith77 Posted November 10, 2015 Report Posted November 10, 2015 you're going to want 3.5-4 and no bigger what ever amp you choose make sure you are going to be able to deliver about 4k to each sub.. anything less and you might as well go with a sp4 I would listen to this guy... He knows a thing or 2 about the teams.. Just sayin. Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born. My penis is bigger than your penis I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
