What amps do around 1000 rms @ 2ohms @ 12 volts???
akuma4u
Hi
Im looking for an amp that does around 1000 rms (900-1200rms is ok too) @ 2 ohms at 12 volts...
i notice that most amps rate their numbers at 14.4v but my voltage, and im assuming most peoples voltage dips below this so we are hardly ever seeing those numbers..
perhaps, and i would need confirmation on this, if i want something that does around 1000 rms at @ 2 ohms at 12 volts I should be looking for an amp that does around 1400-1500 @ 2ohms at 14.4v ?? the 2 volts voltage drop should bring it down to around 1000 rms @ 12v? is that how it would work or is this a classic n00b fail that i have just made?
thank you guys for your help
Hi
You wont notice the difference in either dude. Dont sweat it. Grab a 2k rated board at 1ohm and enjoy.
amps that are cea compliant are rated at 14.4 but they are also only rated at 4 ohm so anything lower is just their guess.... with a good battery and charging system you should see between 13.5-14.0 no problem.... engine off 12v is more of a red flag that your battery may be on its way out resting voltage with out surface charge should read 12.5ish.... i wouldnt set up your equipment with low voltage in mind just buy stuff with more headroom..... its never a bad thing to have more power on tap and not use it
A Fosgate T1000bd comes to mind. Maybe a 1500 to give you the extra headroom at 12V. Went it's 12V a concern of yours? Is it going in a boat or something without an alternator?
hey Thanks to all for their replies
my n00b theory goes like this
if i need 1000rms to run my subs properly , then why not pick an amp that can do 1000rms at the worst possible scenario @ 12V. That way you can rest assured that no matter whats going on with your electrical situation, you will be giving your subs what they need - even during the worst possible situation/times.
Kicker CX1200.1, Kicker KX1200.1
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
  • Who's Online   0 Members, 0 Anonymous, 695 Guests (See full list)
