Posted (edited)
his last two posts were four minutes apart. Why am I even humoring this response.....
Oh yeah, can't sleep again.
Dustin, you buying that silverado ?
Also, one day some time soon we should meet up at home depot or lowe's out in pooler . you gotta hear this imprint deck that Alpine came out with....
Edited by trainman0978
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
why cant u do 1 amp per coil? they will be getting same power
Well if he was to do a silly thing like that, it would be WAY to hard and complicated to "match" both amps so that both coils would see EXACTLAY the same power and signal. You could easly fuck the coils if you do it wrong....also if he was to to that, each coil is 2 ohms, so you would see 2 x the power the 1500 does at 2 ohm.....now if he was to seriece the coils to get 4 Ohms, then strap 4 Ohms each amp wouls also see 2 ohms just like the one amp per coil....so there would be absolutly no point at all to do what you said ;)
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
x2. strapping them combines the signal into one, so to speak. only reason you'd wanna do 1 per coil is for burping at comps.
Not to be an enormous cock but... you're the DC Audio dealer for your area... and you don't know how to load amps?
:S
:lol: :lol:
just do 1 amp per coil
:rolleyes:
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
first parallel the two coils on your dual vc woofer...then you will have two leads from the woofer, one + and one - with the sundowns just "bridge" the negative terminals of the amps to each other, and connect the + wire of the speaker to the + terminal on the master amp. then the - speaker wire to the + on the slave amp. be sure to have the RCA's ret right for straping amps
^ The truth
