.5 amp load question
Hey guys i was wondering if i wire an amp at .5 ohms. Then turn the gain down is it possible to have the same outcome on the electrical strain/power as the amp wired at 1ohm with the amp gain turned up to the correct gain setting? What are your thoughts?
may i ask why? i really dont see a point to it..
I want to buy a used sub from someone for super cheap but its dual 1 ohm and dont feel like reconing it until it blows or something bad happens.
You could do that, but then the amp will probably output less power then at 1 ohm.
Since (most) amps are a lot less efficient at 0.5 ohm.
run it full tilt at .5 til the sub blows then recone it :unknw:
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
Just make sure your amp is .5ohm stable and you will be FINE! Everything I run is at .5ohm... Set gain correctly and you will be fine
c-pillar flat wall 157.11db on music
2 crossfire 8k
4 NSV3 18s
4 crescendo 10s
4 Rockford pro 6.5s
Quad excessive amperage 350alts
4 juicebox 3100s
He said he isn't sure of his electrical, he doesn't have Quad 350A alternator and 4 3100's.
dont even bother
the difference between 1ohm and .5ohm is not much and not worth the hassle/risk
  • Who's Online   0 Members, 0 Anonymous, 550 Guests (See full list)
