My system so far . What would you change ?
Second batt or bigger alt? I'd guess bigger alt first.
I did some deadening. Went cheap .. well free with 3 layers of peel and seal on outside door skin from t and rear . 3 layers on the mount panel , also the rear panel. I'll step up for some good stuff for the roof . It did help a bunch .
Could care less about making anyone but me happy with my setup. I just want input from more experienced car audio guys , so I make more informed upgrades from here .
I would do both but if i had to do one first i would do alt. It is my understanding that the Batteries are for when the bass first hits it causes a spike in amperage that the regulator in the alt cant react quick enough to. The batteries Keep the voltage up long enough until the alt kicks in. This all happens in a fraction of a second which is why some people run banks of caps because they react faster than batteries. Caps IMHO get a bad rap for killing alts because they let you keep your alt at max output when otherwise you would have turned it down a little. When your Volt needle bounces, you turn it down a little i hope? When the voltage goes down the amperage must go up to maintain power and can kill an amp. Wattage = voltage X amperage.
Pioneer 80PRS
It was free so I took a chance . It hits 104 here in the summer and I never smell it . Could I layer over it? Stuff is really stuck down , removing it would be tough .
I never thought about damaging my amp . Lol no I usually just add some rpm to bring the voltage up . I love my tunes loud . So really It looking like the very first thing I should upgrade is my electrical before I fvck something up.
Looks pretty good so far. I know how it is, you have a goal and then you meet it and you goal changes. What do you feel it is lacking? If you want it louder is one direction, or maybe staging and imaging are next? At some point you might choose SPL over everything else or that sound quality has priority. I have seen the Zapco DSP but it is expensive. I am stuck in the middle somewhere (loud and clean) as are most people. The ultimate goal is of course the highest SQ system that is also the higest SPL system but nobody has seen that yet.
By the way i love that sub amp. I used to have one until it started making a funny noise.
I beg to differ....I will accomplish this,,, ok maybe not
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
