Passive radiators
Hello, so I have a build in mind for a passive radiator enclosure for the crescendo audio forte 15" I emailed psi audio asking them about what there opinion was and they suggested 2 15" radiators which makes perfect sense and they told me to go with 5.5-6.0 cu ft after the displacement of my subwoofer and both psi radiators and tuning can be as my preference to change by the mass added to the radiators but what im wondering is does anybody have any experience in making passive radiator boxes and does anyone have any suggestions for how I should build this or if you believe you have a better estimate for size of the box in the end im looking a as much sq I can get out of the system as possible for the price im not interested in a dofferent sub or different radiators just need some suggestions
5.5 - 6.0 cubes is awfully big for a single 15".
Have you tried modeling the output in any box simulation software to see what kind of frequency response you are going to get?
Builds:
3.5-4 net is what the manufacturer suggests, anyways the parameters for the PRs are needed to calculate a box.
I thought radiators were to help if the box was too small, like the big bad SMD towers? The highest tuning would be the box with no radiators and go down from there?
Pioneer 80PRS
The box with no radiators would be a sealed box, the highest tuning you can get would be just the PRs without any weight added to them. Adding weight lowers the tuning from there. What frequency they start off at with no weight depends on the specs of the PRs and the size of the box.
Builds:
I got the 5.5-6.0 cu ft estimate from psi so I assume there reasonably correct seeing as how it's their radiator and unfortunately my dog has recently chewed through my laptop charger and im left with no computer but friends ones occasionally but I would love to put it in winisd 8 or something it's 2 psi passive radiators 15" and a crescendo forte 15" also I can post full specs of the radiators in just a moment
Yes, to my understanding it is small as compared to the vented enclosure seeing as how a PR takes place of a vent I would compare the box sizes and the pr box would achieve lower, flatter response in a smaller box than with port also never have port noise
Very interesting. The PR would cause the driven cone to unload more and act like the box is bigger. And give some value of output gain at the same time. I wouldn't know what to do with T/S of a PR but would suspect that some values would aid and some attenuate the corresponding values of the driven cone. I will stay tuned to see if someone will stop by and drop some gold nuggets on us.
Pioneer 80PRS
The box should be built according to the woofer's specs, not the PR's.
Can you also post the woofers T/S parameters?
  • Who's Online   0 Members, 0 Anonymous, 1845 Guests (See full list)
