Chris Braun Posted January 16, 2016 Report Posted January 16, 2016 Any reason why you can't just use wood glue instead of caulk? Also isn't using wood glue to effectively join the 2 pieces of wood into 1 the same as sealing? Has anyone just screwed and glued a box without caulking and tested for leaks? Caulking the box is the best for sealing the box, but without caulking, isn't it technically already sealed? Just curious
audiofanaticz Posted January 16, 2016 Report Posted January 16, 2016 As long as your cuts a straight and you use a proper amount of glue to fully cover the joint you are gluing there is no issues. I probably haven't used caulk in 12 years if not long and never an issue.
poorfish88 Posted January 16, 2016 Report Posted January 16, 2016 Titebond2 or 3 is all I use, I don't even use screws.
audiofanaticz Posted January 16, 2016 Report Posted January 16, 2016 Titebond3 only for me, clamps, and 18gauge 1.25long bradnails
Triticum Agricolam Posted January 16, 2016 Report Posted January 16, 2016 As long as any gaps are small wood glue will work just fine for sealing. If the gaps are big (1/8") or bigger then silicone would be better, but at that point you might want to rebuild anyway. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Chris Braun Posted January 16, 2016 Author Report Posted January 16, 2016 I just see everywhere, glue, then caulk, glue, then caulk. Figured it's just a fail safe for the noobs haha.
Triticum Agricolam Posted January 16, 2016 Report Posted January 16, 2016 I have never used caulk. Never had a leak either. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
alaskanzx5 Posted January 16, 2016 Report Posted January 16, 2016 I use caulk but that because everyone else around me that was into car audio suggested it. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
hdorre Posted January 17, 2016 Report Posted January 17, 2016 I use PL for both, joints and gaps. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Hugh G. Rection Posted January 17, 2016 Report Posted January 17, 2016 I never have, and never will, use caulk or silicone to seal a box. If my cuts are so ragged that glue wont seal it then I have absolutely no business building boxes. Owner of BigAss Ports
