Morning fellow headz!
I would like to know what is the best method to apply damplifier pro to my doors.
1) Apply adhesive to the door it self and damplifier, then seal together or..
2) Apply adhesive to door panel and damplifier, then seal together.
#1 sounds like it would make a more sound contact, but if I have to get a new window, or re-do my tint, I'd have to tear it out.
#2 sounds more practical, but I'm curious if it will affect my custom door panels further down the road. ???
Second, has anyone used butyl rope to help seal their door jams, trunk seal, hood seal? Is this a good idea, or...????
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
my bad...luxury liner pro...not damplifier pro...
Singer 220 amp alt
* Requires contact spray adhesive (1 can per 4 sheets)
says it right on the site
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
Thanks Leo, I know. My question was adhesive on the door and liner, or on the door panel and liner. I really like the idea of industrial Velcro.. Not permanent, but very secure.
Singer 220 amp alt
any input on butyl rope being used to help seal door/trunk/hood seals?
Singer 220 amp alt
I personally would not use contact cement that comes in the aerosol cans.
It will get down right expensive if your doing a lot of liner and the price you pay for some 3m super 77 or 90 is not worth it at all when you can get a gallon of the good stuff for $20-30...
This Weldwood Landau top and trim contact cement is the best there is.
http://www.ebay.com/itm/like/281094382720?ul_noapp=true&chn=ps&lpid=82
It is the industry standard in car audio and even upholstery for wrapping vinyl/leather/enclosures.
It wont let go due to high heat or humidity like other contact cements do.
You typically have to order this stuff.
If you want to buy some at a local store this is the same manufacture but does not hold up to high heat no where near as well, but still works great.
I tend to use it here and there for carpeting speaker boxes when I run out of the blue can stuff and need to get a box done, still never had a issue with it either.
But I wouldnt trust it for wrapping of headliners, door panels, or any other items that get exposed to direct sunlight for long periods of time, or that has a lot of stretched vinyl.
http://www.lowes.com/pd_41163-68-00273_0__?productId=3033218&store_code=2206&cm_mmc=SCE_PLA-_-Paint-_-Glue-_-3033218:DAP&CAWELAID=&kpid=3033218&CAWELAID=1368052019&k_clickID=65711157-4741-4a18-847e-1f72e7d7d1de
Both of these you can spray it on if you have a compressor and a hvlp spray gun, otherwise just using cheap foam or chip brushes is fine too.
Apply to both the liner and the panel of the door, let tack up so its dry to the touch and then mate the two together.
How exactly are you wanting to use this stuff?
Because if you put it around your trunk and hood to make a seal chances of getting said item to open back up again will be slim.
It is all butyl and there is no non-stick surface on it like there is on a deadener, so whatever it touches or gets compressed too will pretty much be stuck together.
Opening said door, trunk, or hood would be a lot of work like trying to remove deadener that you previously installed.
Thanks audiofanaticz! I've never really seen the butyl rope before...I wasn't aware of it being two sided! I'll check in to the products you listed above. Back to my question, when gluing liner, would it be best to glue liner to door panel, or liner to door?
Singer 220 amp alt
