Fiat Panda Super Street 1-2 Build - Updated 30/03 160dB++
Got a lot of work done this week :) I feel the end of this project is getting closer and closer, i can't wait until the first burp :yahoo:
Finished the floor. Total of 12mm deadener everywhere with 98% coverage.
Putting the "dashboard" back was a pain with all the deadener in place.
Rear wall was welded to the frame.
Side walls welded
I couldn't weld the plate from behind so i choose to drill holes and fill them in.
I used this awesome core drill with electromagnet at the bottom.
Current setup
DD Z318 Extra Stiff, Kevlar cone, Double top plate x2
Banda Viking 10k x2
5 Banks of Maxwell 2.85v 3400F caps
Build log Termpro Profile
Are you putting wood over the steel? I would be worried about resonance with the steel panels and no wood
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
I wont put wood over the steel. I will have to see if i will have problematic resonance when i test.
There are other SS cars built this way without problems.
Current setup
Banda Viking 10k x2
That mobile magnetic 'drill press' is awesome!
Static drops are my bag.
  • 4 weeks later...
I have been slacking on updating you guys. I still have a shitload to do and only 12 days until the Panda is supposed to be ready :shok:
Made some "swiss steel" so i could weld the plate to the frame.
Floor welded
Drilled lots of holes in the roof plate
Jacked it up against the frame, this was a pain in the ass to do by myself :(
Done
Welded the angled sections
Made some "fill-in" pieces around the wheel wells
Bent steel so i would get a nice round shape over the wheel wells
When the welding was done i started laying putty and sanding to smooth things out. No pics of this tho.
Built a baffle and installed it using super strong glue and thick steel brackets i made.
Current setup
Banda Viking 10k x2
Holy SHIT!!!!! Insane. mobile bomb disposal right there
  • 3 weeks later...
Time for an update! I got the car playing in time for the competition. Still a lot of work to get the car to it's full potential but i will get there during the season!
Painted the rear wall and began foaming around the frame
Made covers around the wall using cheap Ikea blankets, fiberglass and resin :)
Welded a simple battery holder.
Loaded the Z subs B)
Still need some finishing touches aka Paint :lol:
You should be able to lean your seat into a proper sized port ;)
In the Lane :yahoo:
The Panda preformed over my expectations. This was on ~6000w clamped power :D
I also scored a 159,7 on 4000w clamped B)
The weekend left me with two 1:st places, one second place and one third place.
Best score were 161,6dB. Which is also my Personal Best :hi:
Current setup
Banda Viking 10k x2
  • 5 months later...
update yo!
...I know something you'd want to share ;)
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
Long time, no see.
Figured i would update you guys now that the season is over. I have spent a insane amount of time on the car to improve the results and i have succeeded B)
The summer started with me cutting the baffle out of the car as i wasn't satisfied with it.
New, better baffle installed and painted.
The nice paint didn't last long with all the testing going on :P
Reinforced the rear wall as this was the weakest spot of the shell.
New electrical and amps :good: Two Banda Viking 10k and 5 banks of 2.85v Maxwell caps. Also bought myself a new charger, DD SPS-100.4
Reconed the Z subs so i could achieve lower nominal impedance.
Last weekend i went to the Swedish Db Drag finals and took First place with a top score of 165,8dB with 16,5kw. B)
So, to recap. I built Sweden's loudest SS1-2 car ever over a period of nine months, won the Championship and set a new Swedish record.
I'm pretty happy with the performance of the Panda so far. But it can always get louder :spiteful:
The goal for next season is 167dB under 25kw. Which should be doable over the winter with the changes i have planned :good:
Current setup
Banda Viking 10k x2
  • Who's Online   0 Members, 0 Anonymous, 2233 Guests (See full list)
