White Lightning Posted March 6, 2016 Author Report Posted March 6, 2016 Sweet I have a 98 step side. Interested for what's to come. Thanks bro. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
ShadeTreeMechanic Posted March 6, 2016 Report Posted March 6, 2016 My doors are just like your 88. Does the stock grill get in the way? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
White Lightning Posted March 6, 2016 Author Report Posted March 6, 2016 My doors are just like your 88. Does the stock grill get in the way? So far ... No, shouldn't be a problem. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
White Lightning Posted March 6, 2016 Author Report Posted March 6, 2016 My doors are just like your 88. Does the stock grill get in the way? One unique feature that I have found with these doors is there would be minimal modification to fit a musical 8" midbass driver in factory location. Tempting ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
reedal Posted March 6, 2016 Report Posted March 6, 2016 Do ittttt SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
White Lightning Posted March 6, 2016 Author Report Posted March 6, 2016 Do ittttt 2 way 8 & tweet fully active on 600w RMS huh ... ???Really tempting ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
ShadeTreeMechanic Posted March 6, 2016 Report Posted March 6, 2016 I have seen 8s and 10s with coax horn tweeters that go through the pole piece of the mid. An 8 can fit. When I cut out for 6.5s it looked like there would be enough to cut out. But to cut out that much wouldn't keep it centered in the grill because more would have to be cut from the side of the hole. I don't know if that would be a problem or not. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
aculous Posted March 6, 2016 Report Posted March 6, 2016 cone acts as a waveguide. You get some problems sometimes with breakup. Ciare has some really nice coaxs and BMS does too. But damn you are talking about a LOT of depth that you would need. BMS has the ultra low distortion drivers. Also they have the 2" midrange compression drivers that are super nice. Assistance Audio had them make a custom coax that is really nice too.
White Lightning Posted March 6, 2016 Author Report Posted March 6, 2016 I have seen 8s and 10s with coax horn tweeters that go through the pole piece of the mid. An 8 can fit. When I cut out for 6.5s it looked like there would be enough to cut out. But to cut out that much wouldn't keep it centered in the grill because more would have to be cut from the side of the hole. I don't know if that would be a problem or not.If I can't make them center up with angles ... I have no problems sticking with the 5.25" drivers. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
White Lightning Posted March 7, 2016 Author Report Posted March 7, 2016 cone acts as a waveguide. You get some problems sometimes with breakup. Ciare has some really nice coaxs and BMS does too. But damn you are talking about a LOT of depth that you would need. BMS has the ultra low distortion drivers. Also they have the 2" midrange compression drivers that are super nice. Assistance Audio had them make a custom coax that is really nice too. I like coax drivers, but don't see them as an application for this truck. The only reason is consider 8s in the doors would be no need for sub bass drivers behind the seat. I'm thinking the 5.25" midrange driver will be my best option for what I'm wanting out of this system. Most likely will be fully 2 way active if I can't find a suitable location for my passive crossovers. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
