Speaker size configuration questions
Jhunt94
I have a 2016 mustang that I recently purchased, and I am intent on doing an sq setup in the car. I'm not really sure as to how I need to go about picking which speakers I need to replace. The car originally came with 9 speakers. In each door there is a 6.5" mid and a 3" mid, tweeters in the A pillars, a 3" mid in the center of the dash, and two more 6.5" mids in the rear deck. I have several options that I have been thinking about, and want to throw them out and get some feedback.
Option 1
- 1 6.5" per door
- 1 3" mid per door
- 1 tweeter per a pillar
- no center dash mid
- no rear deck mids
Option 2
- 1 6.5" mid per door
- 1 3" mid per door
- no tweeter
- 2 6.5" mids in rear deck
Option 3
- no 3" mids in door
Other options are gladly welcome. I'm really new to the whole sq side of the car audio world. I've done some research, but I'm not to proud to ask for help when it comes to something like this.
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
First you want to decide on the numbers of speakers you are going to use, and then you want to play with speaker placement which can take a fair amount of time to get right. You'll want to tape the speakers in various locations to get an idea on how well it will image and sound so you have less work to do in processing.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I guess I might should have said this earlier. I want to utilize the stock speaker locations, because I just got this car a couple weeks ago and don't feel comfortable cutting up panels.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
Why not order a pair of a pillar plastics. So then if you.need.to put the car back to stock, swap out the speaker pillars for the stock ones
After you mentioned the tweeter and mid in the a pillar, I actually did try to find some pillar plastics. I'll have to do a little more searching, and deciphering of ford parts websites. I'll probably either do that or just go with option 1.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
https://parts.autonationfordwhitebearlake.com/
but they have not listed 2016 as an option at this time but this is the site/dealer that just about all the members over at the other ford based forums I belong to use... you will not find better pricing from real ford parts unless you have a connection at a parts counter
Perfect! Thank you, that website is so much easier to use. Also the 2016 is the same body style as the 2015, so it should fit.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
First thing I would do is upgrade to an 8" driver per door.
Leave the rears alone and just fade to the front. Work on those at a later date.
  • Who's Online   1 Member, 0 Anonymous, 1470 Guests (See full list)
