A single Sound Qubed HDS315 along with the Q1-1200.2 amp.
Build your own box about 4.5 to 5 cubic feet. Tune port to 35hz. Many of us learned how to build a box due to budget reasons.
Pioneer 80PRS
Why not save up more money and start with better gear?
You don't have to start with the entry level stuff.
If you build your own enclosure and don't include that in the budget you could do a little better.
Also you could hunt down great deals of used gear.
$350 get's you a Soundqubed HDS208, alpine m500, knu or SQ wiring kit, and add $40 for wood and done.
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
Dual 12" ported box $120 - $100http://www.ebay.com/itm/like/321814571804?ul_noapp=true&ul_ref=http%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-117182-37290-0%2F2%3Fmtid%3D1588%26kwid%3D1%26crlp%3D53601919689_324272%26itemid%3D321814571804%26targetid%3D154774689609%26rpc%3D0.14%26rpc_upld_id%3D63067%26device%3Dm%26mpre%3Dhttp%253A%252F%252Fwww.ebay.com%252Fulk%252Fitm%252Flike%252F321814571804%253Flpid%253D82%2526chn%253Dps%26adtype%3Dpla%26googleloc%3D9032536%26poi%3D9032552%26campaignid%3D239125209%26adgroupid%3D14978428809%26rlsatarget%3Dpla-154774689609%26gclid%3DCj0KEQiA89u1BRDz8enExq7rvN0BEiQAaFCHm-rXIlRT7XHL4pUo31ljzV0xjKMiswlPmt69KkD1K_AaAk2P8P8HAQ%26srcrot%3D711-117182-37290-0%26rvr_id%3D978744130754&chn=ps&lpid=82
(2) 12s $260 - $240http://www.amazon.com/Rockford-Fosgate-P3D212-500-Watt-Subwoofer/dp/B001AUYWJE
Wire kit $30http://www.amazon.com/Gravity-GR-0KIT-PRO-Amplifier-Installattion-Flexible/dp/B00KRKNTLK
Amp $120http://www.sonicelectronix.com/index.php/lp/pla-monoblock-amplifiers/r500x1d?utm_source=google&utm_medium=cpc&utm_campaign=PLA&scid=scplp3798045&gclid=Cj0KEQiA89u1BRDz8enExq7rvN0BEiQAaFCHm5VmqSxZINAIHhuQvoHozrYkLfhn8ALV0wu6Ld6uik8aAle68P8HAQ
and this is how you make an insurance claim since your car burned down
That wiring kit is suspect for sure.
I'd run the amp and subs though although you could get a better performing sub in that price range.
exactly. only thing I clicked on was wiring kit. If you're skimping out on the bloodlines, then the rest of the build will suffer
that kits wire size should be around real 4gauge which is good enough for that small amp
