'08 Honda Fit *Evil is in and a VIDEO*
Made some good progress over spring break
received_1089140907807300_zpsebmzrsbq.jp
received_1089145577806833_zpshews1taw.jp
April fools :peepwall:
Hahahaha. You're lame here. :P
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
Well this is what I'll be working on this weekend. It'll be birch, with stain and 3 coats of poly
wow im suprised thats all it was shipped in.
Why?
Anywho, lookin good Grant :good:
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
that bitch could've been dropped from 6ft and on the edge and it would've survived. metric fuck ton of bubble wrap. Not to mention the dude who repaired it loved hot glue, errywhere
edit: although he doesn't know how to tighten the ground block onto the board :peepwall:
Let me know if you want or need some tips on stain/poly. :)
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
Well the wood surface hardness will take into play how much you have to sand, but for the wood I use (poplar) I start with 150grit and do about 3-4 full passes with that. Then I do 2 passes with 220 grit. Then the box is wiped down with a microfiber towel after being blown off to remove as much dust residue as possible. I do 2 coats of stain, for this each coat is applied with a small horse hair brush ALWAYS following the grain. (These are the 1.20 each brushes you find at homedepot) After letting the stain set for 15 mins I wipe off any excess stain and then let it cure for 2-4 hours. Then the second coat of stain is applied just as the first. The final coat of stain is allowed to cure for 4-8 hours or sometimes I let it sit overnight.
For the poly, before I apply the first coat, the entire box is smoothed out with 0000 steel wool, and blown off and wiped down with a microfiber towel. The poly is also applied with a horsehair brush ALWAYS applied following the grain. This is allowed to cure for 4 hours, then smoothed down with 0000 steel wool. Then again blown off and wiped down, then the final coat of poly is applied just as the first was but allowed to cure for 24 hours.
This is the method I used for the box in the picture I posted, it may not be the best method, however I have never been disappointed with the results.
  • Who's Online   2 Members, 0 Anonymous, 1102 Guests (See full list)
