Allen Lancos Posted February 9, 2016 Report Posted February 9, 2016 Got my Fi's in today, what are you guys using to mount these monsters? There is only about 1/2" max of mounting surface to run fastener through, not to mention the suround is glued over the holes. image hosting 30 mb im concerned the surounds may be damaged by the fasteners. I'll do body filler all day every day, but this reinforced, fortified fucking kitty hair can kiss my balls.
rocking.that.eclipse Posted February 9, 2016 Report Posted February 9, 2016 So what we have had to do so the screws don't catch is come from the back side (in the least sexual way) and drill out the surround from the holes I believe the largest screws that can fit without drilling out metal are #12s
Allen Lancos Posted February 9, 2016 Author Report Posted February 9, 2016 Damn i just got home with 1/4 hex bolts, hole diameter is .230 shouldnt hurt to step it up to .25 I'll do body filler all day every day, but this reinforced, fortified fucking kitty hair can kiss my balls.
Kyblack76 Posted February 9, 2016 Report Posted February 9, 2016 Ream the holes out prior to mounting, spax 12 will work fine. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
hdorre Posted February 9, 2016 Report Posted February 9, 2016 With the TI baskets Ive played with, #14 is the largest that fits. With that being said, there is NOTHING wrong with #12. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Allen Lancos Posted February 13, 2016 Author Report Posted February 13, 2016 free upload pictures Im sorry but this just seems downright risky! If someone accidentally catches the surround and puts a hole in it, you are SOL, would warranty cover that? Seems like a trick to possibly sell more recone kits to me. Maybe its just my opinion but this is something that should be done by the manufacturer. Subwoofers should come ready to wire and drop in! Luckily i got all the hole done with no issues so far. When i tighten these bolts down, what is the possibility of the suround tearing at the edge of the bolts since the moving edge is so close? I'll do body filler all day every day, but this reinforced, fortified fucking kitty hair can kiss my balls.
ChevyBoy95 Posted February 14, 2016 Report Posted February 14, 2016 Not a trick to sell recones dude, just use common sense. I hold my 85+ lb subs into a flat wall with spax #10 2" screws. Go to your local hardware store, they should sell a shielded bit that accepts bits (like phillips, flathead, etc.), put the phillips head on the bit, slide the shield over the screw and screw it in, basically makes it where it cant slip off to hit the surround. http://www.homedepot.com/p/Ryobi-Bit-Holder-Set-3-Piece-AR2019G/205193167 Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
