New Sony receiver
shogen
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
Yeah, $1500 damn.
The front micro USB is kinda weird tho. I don't think I'd be using my laptop in the car.
Thinking it's meant for adjustments and maybe upgrades to firmware.
Front-Panel microUSB Port: The Sony high res digital media receiver is equipped with a front-panel microUSB (type-B) port to connect a high resolution audio source like your Windows PC, Mac laptop, or high res portable audio player. You'll be able to playback DSD & PCM high resolution music files. There is no playback control from the head unit or remote control, and there is no song/artist/information display or no elapsed playing time or track number display. You will need to control music playback and view song/artist information from your high res source device.
  • Windows PC: To play high-resolution audio files on your Windows PC through the Sony digital media receiver, you will need to download the Hi-Res Audio Player orMedia Go software for Windows. A Windows PC also requires installing a dedicated Sony USB driver.
  • Mac Computer: To play high-resolution audio files on your Mac computer through the Sony digital media receiver, you will need to download the Hi-Res Audio Playersoftware for Mac. No additional driver is required for a Mac computer.
Note:
The unit's microUSB (type-
B)
port is labeled "USB-DAC" on the source display. The unit's microUSB (type-
B)
port is not compatible with Apple iPod/iPhone/iPad devices.
Compatible Audio Files: Playable file formats, sampling frequencies, and bit depths differ depending on whether the USB (type-A) port or the microUSB (type-B) port is used.
Music File Formats Front-Panel microUSB (type-B) Port Front- or Rear-Panel USB (type-A) ports DSD
ASIO Native: 2.8 MHz/1-bit, 5.6 MHz/1-bit
DoP: 2.8 MHz/1-bit, 5.6 MHz/1-bit
Playback not supported PCM Max. 192 kHz/24 bit Playback not supported DSF Playback not supported 2.8 MHz/1-bit (PCM convert) DSDIFF Playback not supported 2.8 MHz/1-bit (PCM convert) WAV Playback not supported 192/176.4/96/88.2/48/44.1 kHz; 24-bit
192/176.4/96/88.2 kHz; 16-bit AIFF Playback not supported 192/176.4/96/88.2/48/44.1 kHz; 24-bit
192/176.4/96/88.2 kHz; 16-bit FLAC Playback not supported 192/176.4/96/88.2/48/44.1 kHz; 24-bit
192/176.4/96/88.2 kHz; 16-bit ALAC Playback not supported 192/176.4/96/88.2/48/44.1 kHz; 24-bit
192/176.4/96/88.2 kHz; 16-bit AAC Playback not supported 16/22.05/24/32/44.1/48/88.2/96 kHz; 16-320 kbps WMA Playback not supported 32/44.1/48 kHz; 16-320 kbps MP3 Playback not supported 16/22.05/24/32/44.1/48 kHz; 16-320 kbps
well then your his res audio player .... like one of these:
Front-Panel microUSB Port: The Sony high res digital media receiver is equipped with a front-panel microUSB (type- B) port to connect a high resolution audio source like your Windows PC, Mac laptop, or high res portable audio player. You'll be able to playback DSD & PCM high resolution music files. There is no playback control from the head unit or remote control, and there is no song/artist/information display or no elapsed playing time or track number display. You will need to control music playback and view song/artist information from your high res source device.
Note:
B)
B)
Compatible Audio Files: Playable file formats, sampling frequencies, and bit depths differ depending on whether the USB (type-A) port or the microUSB (type- B) port is used.
Music File Formats Front-Panel microUSB (type- B) Port Front- or Rear-Panel USB (type-A) ports DSD
I think it's sexy as hell
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I'd buy the dex-p99rs over this any day.
Not me it's still a pioneer so you look at it funny and you'll end up wh a bad Pico fuse and ground loop
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1064 Guests (See full list)
