custom 4/0 lugs / bolt terminals.
I'm making my own lugs to save some money I have a question but first basically how i am going to make them is pound some pipe flat on one end drill a hole put the wire in the other end and pound it to "crimp" the wire on the connector my question is obviously the connector might not be perfectly flat and or it may have pitting for example if i pounded it on the sidewalk so my question is for good connection should i wrap it in copper foil. this way the foil will compress and form to fill pits or uneven areas where connection wouldn't otherwise be made... but if i use a lot it may have wrinkles or areas/pockets of air in the foil of course you could fix this for the most part by compressing it (tightening the connector) but this may not be possible to apply this much force if you are tightening the lug to a battery or you may strip it out. so the question is should i use foil and if so how much?
it is possible if you use the right terminals and tools.
You're probably going to hammer them so they stay put too right? Please don't.
You're going to spend more money in gas, time, effort, materials than you would to grab a few lugs. It's 4/0, you aren't going to have but a few connections. Get some flux core solder, a torch, some lugs and go to down. Or a hydraulic crimper
skyhighcaraudio.com/sky-high-car-audio-2-0-gauge-copper-ring-terminals-w-heat-shrink-tubing-10-pack/
thanks for the link i do think the skyhigh would fit my wire i had no idea you could buy them that cheap but they look like they are that cheap because they have no metal they are very thin looking i know it is only for a short distance, all of the real thick copper lugs are very expensive.
Those lugs fit 4/0 wire
And believe me, you won't say they're thin when you hold them in hand
+1 i just bought a bunch of stuff from shca which included some of these lugs fuckin hell they are beefy
  • Who's Online   0 Members, 0 Anonymous, 807 Guests (See full list)
