Just my 2 cents, your not wanting to spend any or very little money yet you want more output! But at the same time you are wanting to put more load on your already struggling power system. In doing so you could very well cost yourself more in the end than you would if properly upgraded your electricals. Putting more load on your power hungry amp can lead to failure, putting more load on your alternator which sounds to be working at full capacity could also lead to failure. Yes adding another battery will help you maintain voltage "longer" but once you drop that supply you are again at the mercy of your factory alternater.
Another alternative would be to look at your current setup. Is your box prefab or custom built? A custom box tuned correctly could give you the additional output you are looking for. But you still need to upgrade your electricals if you drawing more power than your system can produce.
Example being i just went from 4 (12's) in my truck down to 2 (12') in a proper tuned box and id say i have over double the output i had. Just adding a speaker isnt always the answer! If i were you i would hold off until i got my new ride and completely redesign everything and go from there! "Think i read you were selling current vehicle in the near future"
Most important thing i learned in audio is dont rush it, take the time to do it right!
I'll do body filler all day every day, but this reinforced, fortified fucking kitty hair can kiss my balls.
More batteries will not help the power when wiring that low. If you are already getting into battery power you, you are already not using the alt. Won't help too much, as well, pretty much every single amp is in stable to 1 ohm unless stated otherwise.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Thanks guys I'll probably just stick with what I have then. I could recone to a D1 but I don't see the 3db increase being worth it for $500 more for everything
Good decision, stick with what you have until you get a new ride and are ready to commit to something better.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
You'll never have a 3 dB increase just by wiring lower ! You would need some more batteries and a HO alt : your current electrical won't handle it.
Maybe you just need another custom enclosure ?
Or keep what you have, and start saving and thinking about your new system in your new ride.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Sorry I meant 3db increase from running double the cone area
