Lithium batteries
They're expensive and picky. If you can get around the design challenges they work great
Got a little 20ah jb on a scv 3000 and its worth it.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
JY Power :peepwall:
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Fi Audio Q 10s
Big 3
Singer Alternator
Sky High Wire
a single 40ah lithium with a single good sized alt behind it will hold a 10k all day and barely dip into the 11s after constant demoing. they are really demo designed batteries, at least thats what i tend to say, they have amazing amperage output, safely all the way down to like 8 or 9 volts, way below what most of us feel "safe" seeing. thats where the "demo battery" mentality comes in, spl people need/want high voltage + lots of amperage, demo people just need to have lots of amperage on tap, over almost any range of voltage.
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
i say that because ive seen too many people complain because they replace some AGMs with a single lithium then cry when they have the same "voltage" as before. what they arent realizing is voltage isnt what makes the power, its amperage, and the amperage is much greater and more consistant than the batteries would be
Fidelity
Built to Last
Team Sound Asleep
2 DD M3b
Pioneer DEH-80prs
Higher voltage = less amperage required
Lower voltage = more amperage required
I'm going to say this. If your lithiums are in the 9-10 volt range you have no amperage either. Lithiums stay high voltage much longer then fall off really quickly. If you see 9v your batteries have just shit themselves
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
This image illustrates the effect nicely
http://i.stack.imgur.com/UkodS.gif
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
if you ask the people at juicebox and i would assume the other competitors theyll tell you that they have consistent amperage down to 9v, yes that graph is true but that doesnt tell you the voltage in which the batteries hit the "wall", in the case of the lithiums we are buying, theyve made them so that the amp will protect before the battery is dangerously low. so the "safe voltage" range is say 14v-9v then you hit the wall. At least thats what i was told from juicebox when ordering and inquiring about the 40ah. and im not saying you should be in the 10s while playing, im saying if you find yourself in a serious demo sesh and dont wanna stop, you dont have to be worried when you see 10s because you know your amps are still being fed whatever amperage they need.
Fidelity
Built to Last
Team Sound Asleep
2 DD M3b
Pioneer DEH-80prs
  • Who's Online   0 Members, 0 Anonymous, 901 Guests (See full list)
