High Output Alternators
So I just picked up a 3K amp, and so stoked to use it, just one problem. I can't power it properly! My current 110 amp alt is just not enough. I got voltage drops to about 10.5 and the car feels like it wants to shut off. I contacted Mechman and they said they wouldn't be able to do it. Any suggestions? My car is a 2.0L 2010 Nissan Sentra.
You can try to contact Singer.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
Singer, mechman, excessive, US alt, etc. Personally, i'd say to replace your battery first.
Don't trust a shop but you personally just smoked two decks, makes sense.
03' Trailblazer LT
Dayton Designer 6.5"s & Silkie tweeters
Dayton Audio Ultimax 18"
Pioneer 9601 & 8604
XS Power D3400
2 runs 1/0
Singer 250
Bigger alt , bigger battery if possible, make sure all the connections are tight and clean. You may also check to make sure your cables are OK , sometimes you will have corrosion leach up the battery cable and junk the whole thing.
putting a bigger alt will bog the engine even more.. might help your volts but the engine will suffer lol
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
