Setting gain with DMM
Csprak1990
Ok so I've looked around a bit and was just wondering if I'm doing this right. I multiply the supposed Rms wattage with the impedance,(2500x1) = 2500 and then find the square root which is 50 and match that voltage to the voltage on the amp through the speakers output? Amp is a saz 2.5k
yup. That's how you do it with a dmm. It's never fully accurate though. A dd-1 or oscope would be much better. But I can't say I haven't tuned by dmm before. Eventually your equipment gets expensive enough that it just seems worth it to spend 100-150 on a dd1
1999 Lexus GS 300
Pioneer DEH-80PRS
Singer 240 Amp (Will be installed later)
Northstar Group 31 & 24
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds 6.5 Meso Components
CT Sounds Tropo 6.5
With that said I figure id see how far up on the gain that allows for and just scoot it back a bit. But I just shelled out another 500 bucks for a new alternator and so I'm not gonna be getting a dd1 for a few month or so. But I'll be getting the cc1 soon. Thanks for the help
The only problem is how do you know the signal is clean and that your head unit is at its max undistorted volume?
I only use a DMM for setting if the amp power when its more than the rating of the speakers. Example : my 4 channel is like 400w per channel @ 4ohm. And I'm running a 4ohm 100w speaker on each channel. That way I know the signal better be clean. Every thing else is DD-1.
Well thing is I don't know if head unit is distorting or not. But I've done Lots of homework and can only do as much as my wallet allows for. The head unit is a pioneer avhx-2700 ddin. With shitty 2v outputs. The head unit goes to 40 max. No bass boost, no loud, no unecessary extras. I've done the head unit gain by ear and it almost seems to never distort or sound distorted at almost max volume. But that said it probably is distorting so I've never exceeded 70% . So about 23-27 on volume knob. I'm not tryna be perfect here although I wish I could. Just doing what I can.
Id get the dd1 before cc1 but that's just me. Don't get me wrong it is nowhere near the best method but what I would do is frequently check your subs. Make sure the dustcap isn't getting too hot as well as make sure you dont smell any coil burn. If you dont have either of those there isn't much to worry about. Part of the reason we buy the subs we do is the durability. A dual subwoofer may fry in seconds, ive seen some of these spl subs take some abuse and keep on playing.
1999 Lexus GS 300
Pioneer DEH-80PRS
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds Tropo 6.5
Check the DD-1 Map in Tools forums and see if you can find someone close to you that has a DD-1.. Although I tried the same, found a guy, PM'ed him, never got a response. Found another guy, PM'ed him and we started chatting, but his schedule never allowed him to meet up, he kept blowing me off, so I said screw it and ordered one for myself. I need to add myself to that map, but its worth a shot...
2018 F350 Platinum Hostile w/ Toyo 37 MT's
Big 3
Gately Audio 4 - 8" Enclosure
B2 Audio XM8's
SounDigital Evo 5000.1 2ohm
SounDigital Evo 1200.4 4ohm
AudioControl DM-608
PAC AmpPro - Optical Out
Kleinn Demon Train Horn
Viper DS4+ Smart Start
Just curious, but why are you buying a CC-1 and waiting on buying the DD-1? If it were me, I'd buy the DD-1 first.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
  • Who's Online   1 Member, 0 Anonymous, 494 Guests (See full list)
