Crazy maybe silly idea
Yadaddy
I own a 2003 pt cruiser with stock electrical
I'm getting a 1200 watt rockford fosgate amp
And was gonna get 2 soundqubed hds2 15s
But now I'm thinking maybe getting 4 300 watt 15s and walling off my hatch. Would this be louder than the other idea. Would it be awesome . Would it move lots of air. And would it even have a chance of a hair trick.I'm thinking with cone area taken into consideration this idea of go big or go tf home might be the way to go
I'm thinkin rockford fosgate 15s. If anyone has a better idea with a reasonable price let me know.
Four 15"s walled is definitely going to be louder than two non-walled 15"s on the same power. The question you need to ask yourself is if it's worth the effort to wall for a 1200 watt system.
Builds:
I wouldn't waste my time and money walling for a low power system like that.
Also you should care how it sounds not how much hair it blows, which is likely to be none on 1200 watts.
Your right. How it sounds is more important. I'm wanting to get as loud as possible on my budget. And that is another good point. Would it be worth the effort. Honestly It would be if I thought it would kick ass and sound good. What do you guys think I should do? This is my first system ever and I want it to be as good as it possibly can be
Well I've installed several of my friends systems. And built boxes. So let's say I do keep it simple. 2 hds2 15s ported tuned to 35 hz. What would I learn? I guess even if I don't learn much I would end up with a decent setup and not something people would shake there head at lol
There's some great sounding walls out there. And an efficient setup could get you close to a big number if you test and tune a bunch (at one mic location, not ground pounder or demo monster status).
Absolutely challenge yourself. But more importantly build it how you want it.
Static drops are my bag.
i would say just run the HDC's in a nice box. Trying to wall on 1200 watts doesnt seem like a great idea.
Here is another idea though, wall it and then upgrade later and run more power. But then you are just spending more money that way.
Also, im pretty sure RF has odd ball cutout sizes on most their subs. So walling then upgrading later might cause issues.
No matter what you do it'll probably end up being upgraded later in some way, whether it's power or woofers or both. Build the shell like a bomb shelter and keep the baffle upgrade-able.
A low power wall done right is hugely impressive
Look at jeepandbass. 3.5k doing a 57
Shit mine even impressed people and it does just shy of a 50 on 1300 watts
Get crazy with it. It's really easy to swap amps and even subs. Build the wall to be loud and you won't regret it
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 8296 Guests (See full list)
