How much weight added to a vehicle is to much? when should you start looking for heavier duty suspension parts and what parts in general should you be concerned about?
Recently I added close to 600 pounds to the rear of my vehicle
I have a 9 inch rear end in my car so im not to worried about the axle but which other parts should I worry about?
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
Typical suspension ewear will just be accelerated so just look out for the normal things you should be looking out for anyways.
Springs will definitely help, so would helper aribags.
600 lbs ain't no different than having a couple fat chick's riding in the back, you're fine.
kinda figured as much but would be adding a few more batteries yet n them suckers r weighing in 70-80 lbs a piece
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
the brakes im not worried about since they used the same rotors/calipers on a vehicle that was almost 2000 lbs heavier. the pinion seal was recently replaced also. Ill maybe have them check everything over in acouple months to see where Im at
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
The weight rating of some cars is 600 pounds and if you had it full of people and luggage and a full tank you would be over. That's like a half ton truck that you can't fill up with anything because you will be over. Make sure to keep your brakes in top condition because panic stops when overloaded need no surprises. (ask me how I know) lol
Edit:spelling
Pioneer 80PRS
vehicle type prolly has a lot to do with weight limitations
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
Sure people overload their shit all the time. When they get in a wreck, they get nailed for being overloaded and get blamed for causing it even if they didn't.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 867 Guests (See full list)
