sound quality differences between mono amps
VDub916
I'm using monster cable rca's. I tested continuity and they did good. Headunit has 4v pre outs and those tested good also.
As soon as you connect the headunit to the jl amp, you can hear feedback through the door speakers.
I've also been told that pioneer headunits aren't compatible with jl Amps due to pioneers rca pre amp issues. I haven't been able to find any information on this though.
I don't know what to say at this point
The amp does have sensitivity adjustment but it does not have any effect on the feedback in getting. Engine whine when car is running and weird feedback when the car is off and any sort of electrical accessory is used.
There should be a rca low/hi input switch and a rca sensitivity dial on the amp. Have you tried changing those?
Besides ground loop, rca settings, amp not liking the ground. I dunno what else besides bad amp or just not liking your deck.
According to the manual, 2-8 volts is supposed to be high input. I can try switching to low input but I feel like it would probably make it worse.
Anyway to test the amp for this problem?
Rca's are low input, the high input is for when you're using a speaker wire input to get signal from a factory stereo.
I'm assuming the amp is used?
Did you test it before buying it?
What does your ground look like? (post a good picture if possible)
I would still test with other RCA's, I haven't had great experiences with Monster.
To answer the title of this thread: Not really, unless you are picking extremes.
The change in perceived sound quality you might hear is because of power differences.
To address the high low input confusion, jl used a high low switch on the rca in, low is up to 2v, high is 2-8v.
With the type of rca ins they used, ground loop is less likely. My suspicion is the amp doesn't like the ground.
Leave it to JL to add confusion to something so simple...thanks for the clarification though!
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
  • Who's Online   0 Members, 0 Anonymous, 4622 Guests (See full list)
