rizzy71 Posted May 9, 2016 Report Posted May 9, 2016 I have a 1997 GMC Yukon that is having tail light problems. When the lights are turned on I do not have taillights or brake lights. If the switch is off the brake lights work fine. When the turn signal is on, the opposite side blinks too, but its very dim. I have replaced everything that I can think of or that I have found when searching that might be the problem. All front lights work properly. REPLACED: All exterior light bulbs All fuses and relays that are for lights Rear circuit boards Brake switch Grounds for the tail lights Three different main light switches Any help or other ideas are very appreciated. BRENT1997 GMC Yukon1-DC xl18"Stetsom 2K5E3-Kinetik HC1800's 1967 Pontiac GTO
reedal Posted May 9, 2016 Report Posted May 9, 2016 I just recently fixed this issue for my uncle's OBS Silverado. Unfortunately, one of the issues was the ground you said you replaced. On the rear most center of the frame. Do you have a trailer harness? That was also causing issue as the wiring was old and cracked and grounding out. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
audiofanaticz Posted May 9, 2016 Report Posted May 9, 2016 Has the vehicle always had this issue, or has it just started happening? Im with reedal on trailer wiring either being shorted out from exposed wires, or not installed correctly. You may have to crawl under the back to see if you have it wired for a trailer, sometimes people tuck them up pretty well.
reedal Posted May 9, 2016 Report Posted May 9, 2016 Another question, does it affect your dashboard and license plate lighting at all, or just the rear tail lights/brake lights? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
rizzy71 Posted May 10, 2016 Author Report Posted May 10, 2016 I just recently fixed this issue for my uncle's OBS Silverado. Unfortunately, one of the issues was the ground you said you replaced. On the rear most center of the frame. Do you have a trailer harness? That was also causing issue as the wiring was old and cracked and grounding out. I unhooked the tailer harness back last summer because the wires were starting to crack. I just unhooked it at the T. Has the vehicle always had this issue, or has it just started happening? Im with reedal on trailer wiring either being shorted out from exposed wires, or not installed correctly. You may have to crawl under the back to see if you have it wired for a trailer, sometimes people tuck them up pretty well. I unhooked it back last summer and the problems just started a couple weeks ago. Another question, does it affect your dashboard and license plate lighting at all, or just the rear tail lights/brake lights? It's only in the tail lights and brake lights. BRENT1997 GMC Yukon1-DC xl18"Stetsom 2K5E3-Kinetik HC1800's 1967 Pontiac GTO
ShadeTreeMechanic Posted May 10, 2016 Report Posted May 10, 2016 Sounds like you have a floating ground. I have seen this many times on trailers. Check it with a test light. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
