Help using hydraulic crimper
Wehan
I got my first hydraulic crimper, a 16 ton model and tried to do a few lugs but they look like total ass. I have Knu 1/0 OFC and SHCA 1/0 copper lugs. Was trying to use the #70 die but I'm doing something wrong. Striped off enough wire and put the terminal on and then held it all together as I pumped the crimper up and let it do it's thing, I get big ole nasty pinched wings on the sides of the lug so I flipped the lug 90* and tried to crush the wings down but that just made a whole lot of ugly, also I cant get the dies to bottom out, there is at least a 1/8" gap when the crimper gives up. Am I using to small of a die?
most likely, i usually start with a larger diameter die, get it compressed a little, then swicth to the smaller die to fully compress it. you should be able to do it with one die if you find the correct size with the correct terminals
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
How much of the wire are you stripping off to make it fit in the terminal?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Stripping off about 1/2 inch or maybe a bit more, just enough so it fits but I'm not forcing it in there. I think I got it figured out. I was using a #70 die but I tried the next biggest one, #95 and it is working beautifully. I cant get the lug off the wire with all my strength.
A lot of the car audio cable is oversized to the point where 1/0 is actually the size of 2/0.
Pioneer 80PRS
  • Who's Online   2 Members, 0 Anonymous, 1008 Guests (See full list)
