IKnowImLost224 Posted May 20, 2016 Report Posted May 20, 2016 I've never worked with plexi before but I got a scrap piece from work so I wanna give it a shot. Best kind of saw blade for it? Best way to seal it (caulk, weather stripping, etc)? Any other pre-cautions for a noob?
bsneon98 Posted May 20, 2016 Report Posted May 20, 2016 check this site out: http://www.bcae1.com/plexi.htmI used that when I was working with some 1/2" and they can explain it way better than I can lol Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/
3vil Posted May 20, 2016 Report Posted May 20, 2016 I also think Mark covers cutting plexi in this video
islandpride684 Posted May 20, 2016 Report Posted May 20, 2016 http://www.tapplastics.com/product/supplies_tools/plastic_tools_supplies Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
KiKaZz74 Posted May 20, 2016 Report Posted May 20, 2016 If you have a router and are trying to use it as a mounting ring. Hit up 12vtools on FB. Alot of us have his bits and they are bad ass. Look at the UCC. Solid carbide bit. Will do a single pass in 3/4" acrylic. I did it. As far as a saw I'm not sure. Never tried. From what I've read you want a triple ground tooth and thin kerf. 90° rake angle I think? In line with the spindle. That's for table and circular saws. Good luck though. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
MotorCityFats13 Posted May 21, 2016 Report Posted May 21, 2016 slow and steady dont let the 2 edges melt back together... I use a high tooth count jigsaw blade
IKnowImLost224 Posted May 22, 2016 Author Report Posted May 22, 2016 Thanks guys! Ended up not having a big enough piece for what I wanted to do so I didn't end up cutting it :-/
