bigmizzle99 Posted August 29, 2016 Author Report Posted August 29, 2016 any new progress man im definitely tuned in on this beautiful work in limited space I do have some progress to report. I have most of the finish work done on the box and trim panels and I will post some pictures soon. I'm trying to think of everything I might ever want to wire/install before I start installing in the car and its slooooowwwing me down. I did install 2 runs of speaker wire for each door (going to be active) and that is routed, installed some RCAs for a PAC LC-1 and that is routed from the trunk into the car. Still don't know where I'll put it, but likely mount it in the center console. I want to run some more wires for an OM-1 and a VM-1 and *possibly* some extra RCAs because I wont be keeping this Chevy MyLink radio forever. So, still more to do. I'll post some images later today. Camaro SS Build Altima build 2.0 Altima build 1.0
bigmizzle99 Posted August 30, 2016 Author Report Posted August 30, 2016 Added some deadener Camaro SS Build Altima build 2.0 Altima build 1.0
bigmizzle99 Posted August 30, 2016 Author Report Posted August 30, 2016 Finishing the boxes... A little before and after... BEFORE AFTER Camaro SS Build Altima build 2.0 Altima build 1.0
baller95 Posted August 30, 2016 Report Posted August 30, 2016 Damn that's nice!! Beautiful ride and clean install. Can't wait to see it completed and playing!
Magnus Munk Posted August 30, 2016 Report Posted August 30, 2016 What a crazy ride I fancy that I like the idea about the two part box Got another follower (Y) Best RegardsWhazz - The Friendly Dane My first build log - A Renault Clio II from 2002
bigmizzle99 Posted August 30, 2016 Author Report Posted August 30, 2016 So its going to be sealed? Yes, this box will be sealed. Its not the norm on this site and wasn't that way in my other car, but it was hard to fit both existing drivers plus the port in the 2 box design I'm using. I will revisit the box design and driver later. When the SMD 12 can be bought, I might use it as a single driver ported. We'll see. Camaro SS Build Altima build 2.0 Altima build 1.0
G-Difficult Posted August 30, 2016 Report Posted August 30, 2016 So its going to be sealed?Yes, this box will be sealed. Its not the norm on this site and wasn't that way in my other car, but it was hard to fit both existing drivers plus the port in the 2 box design I'm using. I will revisit the box design and driver later. When the SMD 12 can be bought, I might use it as a single driver ported. We'll see.
G-Difficult Posted August 30, 2016 Report Posted August 30, 2016 I think it would be sweet to, at some point, build a port as a 3rd piece to go in the middle. Then you could compare the difference too which would be pretty cool.
bigmizzle99 Posted August 31, 2016 Author Report Posted August 31, 2016 I think it would be sweet to, at some point, build a port as a 3rd piece to go in the middle. Then you could compare the difference too which would be pretty cool. There is a space limitation. With these 2 pieces bolted together, it fits in between 2 humps in the trunk floor. If I want to make it wider (I do have a sweet design for that) I have to account for the small humps on the floor, which means building indents into the box. So, for now, it can't be wider than it is. Camaro SS Build Altima build 2.0 Altima build 1.0
