d-nice88 Posted July 14, 2016 Report Posted July 14, 2016 Trying to wire to half ohm with 2 dusl 1ohm subs. (Fi) i was wondering if i can wire one in + to + - to - then the other one in series. Then wire them together + to + - to - . When i just wired them that way my multimeter read .5 ohms. Will it work out that way to achieve .5 ohm ?
Efreakingt Posted July 14, 2016 Report Posted July 14, 2016 2 dual 1 ohms subs wire to .25, 1 or 4. Take your multimeter set to ohms and touch the probes together, whatever it reads this way is the amount off from 0 your meter actually reads. Subtract that number from whatever readings you get to know the true readings.
Triticum Agricolam Posted July 14, 2016 Report Posted July 14, 2016 There is no way to wire two 1-ohm DVC subs to .5 ohms. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
d-nice88 Posted July 14, 2016 Author Report Posted July 14, 2016 When i wired 1 in parallel and 1 in series then wire both together in parallel i get at .5 .6 ohm reading. You see what im doing and already did just to see if i could is wire one positive to positive negative to negative. Then wire the other positve to negative positive to negative. Ok now i wired them both together positve to positive and negative to negative and got a .5 .6 ohm reading. That would not work when hooked up to a amp?
ShadeTreeMechanic Posted July 14, 2016 Report Posted July 14, 2016 What ever you do to one sub you would want to do to the other. If you don't then the power from the amp won't divide evenly to all 4 voice coils. You can either do all coils in parallel for .25 ohms. All coils in series for 4 ohms. Or series parallel for 1 ohm. Series parallel would be like putting the two coils on each sub in series. Then hook the two subs in parallel. If you do any of this and do not get these readings then your coils might not be 1 ohm to begin with. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Krakin Posted July 14, 2016 Report Posted July 14, 2016 Half ohm is stupid. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
d-nice88 Posted July 14, 2016 Author Report Posted July 14, 2016 I see shade tree. The one sub that is wired in series would not get as much power as the one in parallel. Makes sense i was just curious since i seen it read .5 .6 ohms and i checked all my coils before hand and they all read 1.0 ohm. Fi make some solid subs. I wonder if i could get away with .25 ohms. You kno including box rise to bump me up maybe .8 ohms or maybe 1. I was just gona test it out
Krakin Posted July 14, 2016 Report Posted July 14, 2016 That's not how impedance works. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
d-nice88 Posted July 14, 2016 Author Report Posted July 14, 2016 By all means school me krakin. I wouldnt of asked this question if i wasnt lookong to learn.
islandpride684 Posted July 14, 2016 Report Posted July 14, 2016 The question is can your amp handle it and do you have enough electrical to support it. Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
