80prs help
split the middle pair of RCA outputs from the 80prs, set the HPF and LPF as low and high as you need for the two mid's amplifiers, then use the filters on the amps themselves to highpass/lowpass to the speakers you want to crossover for midbass/midrange. make sense?
why do you want to use a LOC ? im lost ?
First rca output on the prs80 is for tweets
Second one for the midranges
And third for subs
Want to add a LOC/HLC to have an extra rca output for a midbass amp
Yeah i get it i think, but when adjusting the hu won't it mix up between the midrange's and the midbass
And third for subs
the last thing id do, is put a loc in there, they are shit....... get a dsp then.
And third for subs
you're not splitting the rca's for the mids, you're splitting the rca's for the sub, then setting the low pass and high pass where you can get usable frequencies to both amps, then fine tuning that range with the crossovers on the midbass and subwoofer amp
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
But the subs rca's will already be splitted once because off two sub amps
do you have a pass thru on one of the sub amps?
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
  • Who's Online   0 Members, 0 Anonymous, 984 Guests (See full list)
