Guest Posted August 19, 2016 Report Share Posted August 19, 2016 how does JL specs say they will not run hot? I thought subs always get warm especially if you are playing close to their rms limits Link to comment Share on other sites More sharing options...
boometro Posted August 19, 2016 Report Share Posted August 19, 2016 Looks right to me, what ohm load were you trying to accomplish or think is right/wrong? they are SVC They run hot-- the gain has been set properly with the DD1 - the max volume is 38 as it is tuned to that. When I run the system on 26-29 I can usually smell the wood from the box. The subs cone feel a little warm as well. Everything talked about is connected via 8 gauge wire. Ive been afraid to go above 30 as I fear they will blow. I had a pair before this of same subs but they blew within 4 months. check the gain. just because you used a dd1 does not mean its set correctly. it may be a very good starting point but it is not ALWAYS correct. im not trying to knock a tuning tool but it COULD be incorrect. Link to comment Share on other sites More sharing options...
Daniel Francis Sheppard Posted August 19, 2016 Author Report Share Posted August 19, 2016 how does JL specs say they will not run hot? I thought subs always get warm especially if you are playing close to their rms limits But the amp is giving 375rms to each and the subs are rated at 500 rms... no where near the limits Link to comment Share on other sites More sharing options...
boom50cal Posted August 19, 2016 Report Share Posted August 19, 2016 how does JL specs say they will not run hot? I thought subs always get warm especially if you are playing close to their rms limits But the amp is giving 375rms to each and the subs are rated at 500 rms... no where near the limits how big is the box? sum bitch may be way too big On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
Daniel Francis Sheppard Posted August 19, 2016 Author Report Share Posted August 19, 2016 how does JL specs say they will not run hot? I thought subs always get warm especially if you are playing close to their rms limits But the amp is giving 375rms to each and the subs are rated at 500 rms... no where near the limits how big is the box? sum bitch may be way too big Its a custom ported box made to spec for the specific subs. Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 19, 2016 Report Share Posted August 19, 2016 what over lap track did they/you use??? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 20, 2016 Report Share Posted August 20, 2016 Distortion kills, clipping kills faster. Even with the dd1 you can get distortion because alot of music comes from the recording studio with distortion to begin with. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
White Lightning Posted August 20, 2016 Report Share Posted August 20, 2016 According to the diagram, shouldn't the amplifier be bridged ??? Or does it bridge internally ??? Looks like it's two ohms per side and not one ohm bridged mono ... or am I looking at it wrong ??? Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 20, 2016 Report Share Posted August 20, 2016 Two svc 4 ohm in parallel would be 2 ohm wired this way on a 1 channel amp. If you are trying to get the 1 ohm rated power at 2 ohms you will be kicking its butt for sure. No wonder it runs hot. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
White Lightning Posted August 20, 2016 Report Share Posted August 20, 2016 I was wrong looking at it closer and readimg. Single voice coils ... I'm a dumb ass lol. Two ohm load if the amplifier was bridged. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch Link to comment Share on other sites More sharing options...
