90° or 180°?
Knocker
Due to this being my first ported enclosure the box ended up being tuned much higher than I expected (37 hz). I ended up having to make the port turn 90° and run along the back wall. Now the port is 31 inches long (32 hz) but it runs up to the edge of the speaker cutout. Is it bad to have the port blowing against the side/edge of my Mayhem 18 at high power? If so I can make the port turn 180°. Is a 180° turn a big deal?
Box is 38.75w×21h×22d with 93.75 inches of port area and about a half a cube of 2×4 bracing.
Amp is a BC 5500 (turned down of course) with strong electrical.
As long as you don't have a flat surface directly behind a portion your cone you should be fine. From looking at the pics you posted there really shouldn't be any problems. It won't be as loud as it could be just due to the fact that your sub is so close to the port but it won't hurt the sub in any way.
Ideally you would want the port entrance to be at least a port width away from anything. Yours should be ok I would think.
Pioneer 80PRS
Ok so what if I made the port turn 180° instead and eliminated the issue of the speaker being close to the port mouth. Would it be louder? Does a 180 hurt performance or just reduce efficiency a little bit?
I'd avoid 180 degree turn if possible.
Builds:
^^^ I second this. The less bends in your port the better. It would likely hurt performance to do a 180 instead of the 90 you have now.
Ok in that case I won't do a 180°. Thank you. I looked for info on that and couldn't get a solid answer. Just arguments about fluid dynamics. I think I'm gonna try removing some 2×4 material to increase internal volume then cut back the port a little bit.
  • Who's Online   0 Members, 1 Anonymous, 6115 Guests (See full list)
