Mike4068 Posted September 25, 2016 Author Report Posted September 25, 2016 Ported to manufacturer specs. 500 watt mtx amp 500 watt alpine 15" s type sub.
Mike4068 Posted September 25, 2016 Author Report Posted September 25, 2016 Clipping is referring to the sine wave. When clipping occurs the sub goes from zero to 100 immediately and pushes past the mechanical limits of the sub. Very distinct sound.
ShadeTreeMechanic Posted September 25, 2016 Report Posted September 25, 2016 Over excursion is not caused by clipping. They are two different things. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Kyblack76 Posted September 25, 2016 Report Posted September 25, 2016 Clipping is referring to the sine wave. When clipping occurs the sub goes from zero to 100 immediately and pushes past the mechanical limits of the sub. Very distinct sound. Purposely clipped 2 sets of drivers for years competing. Never heard any distinct noise. Weird. Guess I'm doing it wrong. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Mike4068 Posted September 25, 2016 Author Report Posted September 25, 2016 Elaborate shade tree. I was taught that the clipped wave causes the motor to jump past its limits. I'm always up for education. Why is it just bass mekanik songs that cause this?
Jessica Posted September 25, 2016 Report Posted September 25, 2016 #squarewavelife Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Noel989 Posted September 25, 2016 Report Posted September 25, 2016 Can not convert aac to wav to use in audacity. Boo hoo. Theirs absolutely zero reason To convert from AAC to wav Build Log - http://www.stevemead...-cruiser-el-pt/
Mike4068 Posted September 25, 2016 Author Report Posted September 25, 2016 Only wanted to convert to use in audacity.
