MrSkippyJ Posted September 25, 2016 Report Posted September 25, 2016 I don't recall the exact numbers but it was their recommended volume not the plus or minus. Do what triticum suggested and figure out the actual tuning of your enclosure. That will help us identify or eliminate some possibilities. And if you can, go measure your enclosure, including the port measurements. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
ShadeTreeMechanic Posted September 25, 2016 Report Posted September 25, 2016 Here is the link i was trying to post: http://www.ovnilab.com/articles/clipping.shtml 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Jessica Posted September 25, 2016 Report Posted September 25, 2016 Pretty sure some of that bass mechanics stuff drops pretty low, you play below tuning and good bye soft parts. Edit: there I was helpful. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
bassl0va Posted September 26, 2016 Report Posted September 26, 2016 Determined clipping by the excursion reaching past the mechanical limits of the sub. Sorry, my bad. I misunderstood this for meaning that's how you determined where to set your gains. Do the Bass Mekanik songs drop lower than your usual music? My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
Mike4068 Posted September 26, 2016 Author Report Posted September 26, 2016 That was after I set everything with the dd1. It is my experience that clipped signals make mechanical popping sounds. Just looking guidance not a fight m
MrSkippyJ Posted September 26, 2016 Report Posted September 26, 2016 people are offering guidance, have you used any of that guidance yet? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Mike4068 Posted September 26, 2016 Author Report Posted September 26, 2016 I've tried.guess bass mekanik songs have to be played lower.
MrSkippyJ Posted September 26, 2016 Report Posted September 26, 2016 which ones did you try? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
