Copper speaker wire darkening? what is the problem?
His test are still invalid because he didn't use the same amount of wore or solution for every test,
On order for a test to be valid all things must be equal.
Someone with money could round up some wires and send them to a lab for analysis to find out what the truth is.
Wow good to know. I will stick with welding cable now.
Pioneer 80PRS
The solution only creates an enviroment for the ions to transfer, so as long as there is clearly enough to submerge it is enough.
As for the amount of wire, that only concerns how much could transfer if left ad infinitum.
The only thing that could invalidate his tests is if there was a coating protecting the copper from being touched, ie to prevent oxidation.
Krakin's Home Dipole Project
Fu@k I need to check all my wire now
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
Try again.
Please tell me how the amount of solution past submerging affects the amount of ions transfered during electrolysis.
The only way having more wire would effect anything would be allowing more copper to be transferred over a longer time.
I also did not state his test was valid. I, however, did state a way it could be invalidated.
  • Who's Online   1 Member, 0 Anonymous, 791 Guests (See full list)
