RageQuitForLife Posted September 27, 2016 Author Report Share Posted September 27, 2016 all of the sky high wire i am using is the OFC wire Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted September 27, 2016 Report Share Posted September 27, 2016 His test are still invalid because he didn't use the same amount of wore or solution for every test, On order for a test to be valid all things must be equal. Someone with money could round up some wires and send them to a lab for analysis to find out what the truth is. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 27, 2016 Report Share Posted September 27, 2016 Wow good to know. I will stick with welding cable now. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
RageQuitForLife Posted September 27, 2016 Author Report Share Posted September 27, 2016 well what should i do in the mean time while i try and get new speaker wire? the wire seems to still be working fine Link to comment Share on other sites More sharing options...
Krakin Posted September 27, 2016 Report Share Posted September 27, 2016 His test are still invalid because he didn't use the same amount of wore or solution for every test, On order for a test to be valid all things must be equal. Someone with money could round up some wires and send them to a lab for analysis to find out what the truth is. The solution only creates an enviroment for the ions to transfer, so as long as there is clearly enough to submerge it is enough. As for the amount of wire, that only concerns how much could transfer if left ad infinitum. The only thing that could invalidate his tests is if there was a coating protecting the copper from being touched, ie to prevent oxidation. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
tdsa23 Posted September 27, 2016 Report Share Posted September 27, 2016 Fu@k I need to check all my wire now XS Power D5100, 2 D2700s, & 2 D975s MechMan 220a Alt DC 5K Kicker 650.4 2 12 Ascendant Audio Mayhem's Pioneer DEH-P7200HD Rockford Fosgate 3sity.1 Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899 https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/ Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted September 27, 2016 Report Share Posted September 27, 2016 His test are still invalid because he didn't use the same amount of wore or solution for every test, On order for a test to be valid all things must be equal. Someone with money could round up some wires and send them to a lab for analysis to find out what the truth is. The solution only creates an enviroment for the ions to transfer, so as long as there is clearly enough to submerge it is enough.As for the amount of wire, that only concerns how much could transfer if left ad infinitum. The only thing that could invalidate his tests is if there was a coating protecting the copper from being touched, ie to prevent oxidation. Try again. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
Krakin Posted September 27, 2016 Report Share Posted September 27, 2016 https://en.wikipedia.org/wiki/Electrolysis#Oxidation_and_reduction_at_the_electrodes Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
Krakin Posted September 27, 2016 Report Share Posted September 27, 2016 Please tell me how the amount of solution past submerging affects the amount of ions transfered during electrolysis. The only way having more wire would effect anything would be allowing more copper to be transferred over a longer time. I also did not state his test was valid. I, however, did state a way it could be invalidated. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
rfbasshead Posted September 28, 2016 Report Share Posted September 28, 2016 is sky high really garbage? Link to comment Share on other sites More sharing options...
