Endgame Posted September 27, 2016 Report Posted September 27, 2016 Like a zombie back from the dead .I was working on putting a stereo in my escort 2 years ago and did a bunch of fiberglass work and tons of deadening, running wires and what not. then coolant leak then transmission case broke. was going to fix it and move foreward but the frame was too michigan to throw more good money after bad. threw in the towel and packed up my equipment in the closet. Now the wife has a family car and i have a non work vehicle to play with... Trust No One
Endgame Posted September 27, 2016 Author Report Posted September 27, 2016 Last try I didn't get to build my box so ill go there first this time. then Ill do the battery and amp mounting ,then do some glassing ....anyhow here's what I came up with Trust No One
ckeeler11 Posted September 27, 2016 Report Posted September 27, 2016 NIce work on the port. the octo's look sweet.
Endgame Posted September 27, 2016 Author Report Posted September 27, 2016 One more pic before disassembly ,bracing and painting inside .top and bottom panels they could only be one layer due to height all other sides are two layer ...DC XL m2 15 for the win Trust No One
brian85578 Posted September 28, 2016 Report Posted September 28, 2016 Sick looking box and port all ways wanted to try a Octoport
Smoove Posted October 4, 2016 Report Posted October 4, 2016 damn nice box 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
ShadeTreeMechanic Posted October 4, 2016 Report Posted October 4, 2016 Nice! Strong looking box! 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
bsneon98 Posted October 4, 2016 Report Posted October 4, 2016 looking good man! Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/
Endgame Posted October 4, 2016 Author Report Posted October 4, 2016 Thank you for the upps guys...I got the box done and coated. had good durability with the herculiner in my bronco's interior so why not Trust No One
