Vehicle: Z/28 Camaro (2015)
14650539_10102834420345828_2143023648859
14670855_10102834420146228_1404692126320
14502725_10102834420026468_8699995712887
14570251_10102834419896728_7064703087572
14590378_10102834419796928_8037854181441
Again, work in progress... Project isn't finished. Hopefully we will be finished by Thursday morning. We did test bump the box in a room with a 1200/1 and it sounded really good. We wired the coils up to 4 ohms ( showed 2.96 ohms in the box in the car) and test-ghetto rigged them (just for fun) to one channel of the stock 6x9s and it was actually pretty loud(audible over the stock speakers) on 20w rms! We cant wait to get the project finished!
Love your car!! I'm building my own 2014 Camaro and it has not been easy. Car trunk is way too small, box needs to go in 2 pieces to fit, less than adequate space for amps....oh, and the height of the box is limited to 13" if you push it all the way up to the rear seats. If you move the box back 4" it can be 14" I think.
I haven't decided what to do about covering the battery, either. I have floor trim pieces for amps that effectively make the battery inaccessible. This might be detrimental for dealer servicing the car if they need to disconnect battery.
Haven't resolved that yet.
We had about 2 cubic feet without sub displacement. I think there may be a little more room you can get if you really push the limits of this size, but I am still looking at about ~1.87 cubic feet net(tuned to 33 hz and with a double baffle), and we easily put it in with one piece. I put a picture up here with our measurements. We are mounting some amplifiers above the battery, but should maintain some reasonable accessibility to the battery for service.
Hmmmm, my box is 30" wide x 13 1/2" high x 14 1/4" deep (double baffle). I don't think I even tried to get the whole thing in, I just knew it wouldn't fit. I have 2 12s, so I decided to go sealed this time.
It is possible that that could fit the way that mine did. I think the room is made when you move the stock battery positive cable away from the corner of the spare tire well that it sits in. The opposite corner of the box has to clear the back wall of the trunk and rotate down parallel to the trunk floor. I know I can fit a 14x14x28 cardboard box in there, but I think there is a little more room. If I had two subs like you do, I might try to make two smaller ported boxes or a 4th order in two parts.
We are going to try to make a 4th order (one piece) to fit into another 5th gen Camaro using that 12W6 and similar exterior dimensions.
Nice box set up! lets see those mids insatlled!
Hopefully we will have them up and working tomorrow. We finally got the amplifiers installed and working correctly, but had a few issues running them linked. Apparently the terminals on the sub are marked backwards and + is really -. When we hooked up the amps linked they didn't seem to output sound. As soon as we unhooked the RCA from the linked amp, the primary played fine. We rewired the amps to strap them instead and we were fine. Everything worked ok. We threw the DD1+ on them and I set the gains to a +10db overlap. The deck clipped at 22 out of 40! :shok:
We played a few songs with the stock mids just to see how it sounded and we were pretty happy. We think we are in the 146-147 range but didn't have a termlab available to test.
We have to clean up some of the wiring and do some finishing work still on the back, but you can see it all coming together.
14705646_10102837142879848_4354677557604
14705717_10102837142834938_1275156343816
14695515_10102837142819968_4820110319730
14581380_10102837142795018_3380947059223
14591694_10102837142760088_4447953082213
14591813_10102837142745118_2385181283517
14695523_10102837142685238_5349030481049
14702508_10102837142670268_4820580847680
We got everything hooked up and working for a few minutes of testing before we called it a night. I set the gains up on the 300/2 with a +3.4db gain overlap, but they were so powerful we turned both of them down a ton. I guess we will have to live with having a ton of headroom! The door sound proofing made a huge difference! We are going to try to do some fine tuning tomorrow on the BIT and get everything reinstalled and do some trunk finishing work. ( mount JL amps in final spot).
14717264_10102839078665518_3970896606516
Hooking up both 300/2s including remote wire in next 3 pictures
14358683_10102839078620608_7945137923875
14591736_10102839078271308_4240239338318
14568026_10102839078166518_7724424363924
Finished driver's door. (forgot to take before picture)
14666154_10102839078076698_1580550211532
14731321_10102839077862128_4379655384787
Naked passenger door.
14731319_10102839077986878_2226302038611
Finished passenger and driver's doors
14642033_10102839077757338_5199600272532
14657246_10102839077617618_1292589888552
Connecting amps and setting gains
14720332_10102839077507838_1564163600807
14690952_10102839077198458_1275721509880
closeup of wiring to door
14695364_10102839076539778_2459300014066
14642299_10102839076045768_8851013935817
Showing wiring to driver's door and speaker install
14721479_10102839075930998_2779292593687
14657248_10102839075876108_8485432423128
Passenger's side speaker installed
14731263_10102839075766328_6329223804315
Nice car and build so far man. I wanted to get a Camaro but the damn trunk is just sooooo small for anything large to go in there. However, you are making it work for you. I like what you have done with it so far, keep up the good work.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
14705656_10102840549902148_3660219813830
Thanks man! I have been working on this for years at this point. I am so happy to finally see it through!
  • Who's Online   1 Member, 0 Anonymous, 1561 Guests (See full list)
