Love this build and all the detail you're putting into it. I wish I had your persistence, I always just say screw it and cut small corners bc I just want to hear it play. haha
One thing I thought of though is on the dsp RCA's, what if you mads them loop almost like a "p", might help keep them from sticking out as much. Either way it'll look good, especially once it's all tessa taped
That's not a bad idea bro! I'll give them a little twist and see how it works out.
Generally the wires wouldn't be in a bad spot how they are. The RCA's would be over the AC/heater vent exits under the seat. Technically the B2 DSP is in the line of fire and the way I plan on mounting this (and protecting it from careless feet) then the rear passenger side foot well will not have heat or AC.
Considering how many times I have passengers I don't see that being an issue the 2x a year I'll have passengers back there AND need to cool or heat someone's feet :)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Well I have some updates.
A few goodies
Also some ideas on my 3 way. Here is a sneak peak.
I also started doing this.
Just grouping it at this stage. More to come.
GYZ2Yhi.jpgThen I did this.
Same treatment to my RCA's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Then I found some heat shrink over at Altex.
And techflex time
BAM!
And both colors. :)
More wire goodness.
I also decided to upgrade a CE auto electric relay :)
I also did a poor drawing of an idea I had. This will be the beauty panel that covers the seal off of the subs.
Modeled the shape after the grill of the car.
I will also find a good way to copy the 6
And started looking for trunk ideas
Debating a volt meter location
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Those 12volt metalworking items look AMAZING. Good job with all the tech flex and test tape. Looks professional and clean.
Well its that time again. I took the 4 day thanksgiving weekend and worked on my car some more. I got a TON done. Id say the car is over half way from being done. Also... SHOUT OUT to mazda for being such a awesome car manufacture. You will see in the pictures shortly but this car was practically made for the wiring and equipment that I installed this weekend. It worked beautifully. anyways... picture time. There is a lot.
This was where I started in the morning.
Then I started ripping out the interior and laying down some sound deadening. The floor of this car won't need much. I chose to do about a 70% coverage in this area with 2-4 layers of deadener depending on what "felt right".
Ever wonder what a entire 2016 mazda 6 interior looks like in a small room? Well now you can mark it off your list.
You can see here I put some Overkill pro between the stock AC ducts. They rattled around a little too much for my liking so this is how It went.
I also found some gaps in the B pillars that I put a bunch of foam into. This was mainly just to stop sounds from echoing around inside it.
Needed a break so i went and soldered up my VM1 inside so I could run the wire and tap into my DSP / volt meter cluster.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Forgot a picture of the floor deadened with CDL and some Luxary Liner pro laid down. I did this same treatment on both sides. I still have more but the fitment of this car is TIGHT so i did not want to just go laying expensive vinyl all crazy just to remove it later.
The volt meters temporary home. I want to fab up a small plate that fits in this location for it. But for now its chilling there all wired up.
On the topic of that Volt meter / DSP cluster. Here it is. It is 14ga primary OFC, RED, BLACK, WHITE, BLUE...twisted using the drill method and then wrapped in Exterior Tesa Tape.
Back to the volt meter install. This is where I pulled it through. I used some of the Tesa sticky foam tape to route it along the inside of the console. You will see this tape used a lot. Its white and cloth like but the adhesive is SERIOUS. You will see a few pictures of it holding 2 runs of 2/0 welding cable. LOL. Anyways. Its great stuff. Everything in the car is secured using Tesa Tape of some kind..
After I deadened the floor with CDL I decided to run my wiring on the opposite sides of the car. In this picture you can see my 2 runs of 2/0 welding cable... tech flexed in different colors for identification reasons and nicely routed up the driver side. I secured them every 6 inches or so...
Now this picture looks simple but there is a ton of work to get what you see here. If you look carefully you will see a bundle of speaker wire Tesa Taped up above along OEM wiring and you will see the 2/0 runs routed very cleanly around the kick panel and up to the firewall grommets.
Oh and my awesome girlfriend flush mounted my JL control knob for me. Looks AWESOME.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
