Holy crap that's a lot of goodies. Can't wait to see this start coming under way. I'm sure i'll eventually hear your car bangin' around town. It may be a lot of money now but at least you're doing it right the first time instead of having to change things later down the line. That will save you money in the long run. If you ever need help with grunt work hit me up. I wouldn't be very useful for specialty work seeing as i'm not real strong in any particular skill set but I can help where needed.
That battery looks interesting. What can you tell us about it?
Pioneer 80PRS
I couldn't tell you detailed specifics but I can tell you that they're 40ah lipo batteries rated for 7kW. They're also SUPER light. I couldn't believe I was holding a battery when I picked it up. That's all I got on info though.
Thanks bud! Ill be slowly working on this from now until mid to late Jan. My girlfriend approved all of this on the premise that I take my time and do everything as perfect as possible. and DONT FREAKING TOUCH IT after im done.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
He summed it up. A 100a charge (50 continuous) and this battery would be fine on a 5k amplifier. it weights about 20 lbs if that.. at heatwave i struggled to hold it up by 1 finger for a picture. and im pretty comfortable with 3 fingers holding it. It will rest 13.6 or so... so it will force the northstar up some and will be dragged down some. It won't matter as long as i don't leave the car sitting for a week + and i plan on addressing that for easy access incase i do. This is a great choice for me because i wanted to keep my stock alternator and cut down on weight but still have a decent amount of power. Win win win.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
I'm definitely tuned in, loved the last build as well. What are some box recommendations/port area for those B2s? Looking at getting some new 12s soon and can't find a lot of info for them. Thanks
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
This has all the info for the HN series including recommended enclosure specs.
http://www.b2audio.com/wp-content/uploads/2016/06/HNv3_man.pdf
This is the manual for the IS series which is the series right below the HN series. I have the IS12 v3 and love it.
http://www.b2audio.com/wp-content/uploads/2015/12/el_is_man.pdf
THIS GONNA BE GOOD!!!!
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
With my HN's based on MY PERSONAL experanice. I have had good success with about 2.2 cubes each sub AFTER all displacements. a hair larger at 2.3 wouldn't kill it if your unsure. I tune low... 31 or so. and I had about 24 sq inches of port area per sub. Last box for them was 4.3 cubes tuned to 31, 48 sq inches of port.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Thanks bro! It won't be a large build (i must be scared or something) but im hoping its attention to detail and overall performance makes up for not doing 153's out the trunk :D.
Side note. I have pictures of actual work done to the car. Who wants to see?
I also am still waiting on tesa tape to send me some stuff, Soundrive to send me my RCA's and 12V metalworks to send me my custom machined stuff.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
